UE send to recipients from recordset
Thread begun 4/25/2012 12:24 pm by john70964 | Last modified 4/26/2012 11:21 am by Jason Byrnes | 4255 views | 9 replies |
john70964
Hello
I am trying to send emails to a group of recipients from a recordset so that each has individual
fields ie Title FName LName etc
At the moment the emails are arriving to the correct addresses but just the first record details are being included.
IE
Record ID 1
Record ID 1
Record ID 1
I thought perhaps using a recordset loop for each required field might be the answer but no.
I am attaching an image which will illustrate that.
Any ideas please?
Many thanks
John
see this thread form the universal email forum:
showthread.php?t=17869
john70964
Thanks Jason
I placed this
<body>
<?php echo($RecipArray[$RecipIndex][0]["[ID]"]); ?>
<p>&nbsp;
and received an error
Notice: Undefined variable: RecipIndex in C:\xampp\htdocs\SJP_php2\email.php on line 173
Notice: Undefined variable: RecipArray in C:\xampp\htdocs\SJP_php2\email.php on line 173
re for the email log settings use
where are these please?
Can the wizard not insert individuals details?
no, this cannot be done from the wizard, you need to edit the template file that is created after you have run the wizard.
the code change will not go in the main page that apply Universal Email to, it will go in the Universal Email body template file in the webassist/email/templates/ folder
john70964
Thanks Jason
I think I did as required but still getting just one record in all emails.
I tried attaching the two php files but the Forum attachments will not allow this so sending a zip
you have 3 recordset loops, you should only have 1 for the email column.
in the template file, you have this code:
it should be
<?php echo($RecipArray[$RecipIndex][0]["ID"]); ?>
and you should also have this code at line 1:
global $RecipArray;
global
$RecipIndex;
if you continue to have problems, include the webassist/email/waue_email_1.php file in your attachment.
john70964
Thanks Jason,
In email.php I placed
global $RecipArray;
global $RecipIndex;
at line 1
In Templates.php I placed
<title>Blank Template</title>
</head>
<body style="padding: 20px; text-align: center;">
<?php echo($RecipArray[$RecipIndex][0]["ID"]); ?> at Line 23
I still get the first record only in the arriving email
I am zipping
email.php
templates.php
email_WAUE_HTML_WA_Universal_email_1.php
the code needs to be in template.php, not email .php
in template.php, you should have both pieces of code:
global $RecipArray;
global $RecipIndex;
the 3rd file you sent:
is not the one i asked for, i asked for:
That file will tell e if you editing the correct template file, or even if you are using a template at all, if your not using a template, then the code changes needs to be placed in the webassist/email/waue_email_1.php file, that is why i want to take a look at it.
john70964
Thanks Jason
Zip file attached
