frame rate
Thread began 4/25/2012 9:53 am by turk361661 | Last modified 5/04/2012 8:10 am by Jason Byrnes | 1073 views | 5 replies |
turk361661
frame rate
How do I slow down the rate my power gallery images change from image to image?
Can I add a border around my power gallery?
Currently I'm using Design called "Slideshow - Dissolve" which I have customized a bit using the settings options (I named my new design "portfolio")
Thanks,
Danielle
to change the frame rate, edit the galleries/slideshow_dissolve/js/gallery.js file, the following sets the frame rate:
delay: 4000 //ms
you can change the border of the gallery by editing the
galleries/slideshow_dissolve/css/themes/portfolio.css file, and adding a border to the .pg-sd class:
.pg-sd {
font-family: Arial,Helvetica,sans-serif;
background-color: #303030;
border: solid 1px #000;
turk361661
thumbnails and gallery movie controls
Thanks for the help!
Couple more questions have come up:
1. The thumbnails used in the navigation at the the bottom of the gallery are smaller versions of the larger main images. Is there a way I can use different images for the thumbnails instead? Wasn't sure if this was possible with PowerGallery or not.
2. The "controls" (pause, play, forward, back). When a user puts their cursor over an image the controls appear floating over that image. Is there a way to change the location of the controls so that they appear in the bottom left side instead of the middle?
Thanks for your help,
Danielle
1) no, power gallery will not use a different image for the thumbnail.
2) Please post a link where i can seer the problem to investigate the cause.
turk361661
#2.
Link
www.designdip.com/
Also see attached screen shot.
in the pwgallerydd/galleries/slideshow_dissolve/css/common.css file, edit the top and left settings of the .pg-sd-controller selector:
.pg-sd-controller {
background: url(../images/controller.png) no-repeat;
height: 42px;
left: 50%;
margin: -61px 0 0 -119px;
overflow: hidden;
position: absolute;
top: 50%;
width: 238px;
z-index: 10000;
opacity: 0;
visibility: hidden;
try using 85% as a starting point, you may need to adjust from there to get the desired location.
