Gap between menu and sub-menu
Thread begun 4/24/2012 2:11 pm by chris4754 | Last modified 4/25/2012 7:11 am by Jason Byrnes | 2939 views | 4 replies |
chris4754
Under the Product menu, I have 3 menu items
Under 1 of them I have 5 sub-menu items
The problem is that there is a gap between the menu and the sub-menu when you hover over the menu item with the sub-menu. When therefore you mouse from the menu to the sub-menu, when it reaches the gap, the menu and sub-menu disappear. Therefore it's impossible to ever to click on a sub-menu item.
Any ideas what I am doing wrong?
this is an issue with the setting for the sub menus left attribute.
What version of menu writer are you using? I have usually seen this happen after editing a menu and using the Edit design button in the property inspector to launch the menu editor, as as result we removed that option from newer versions and recommend using the Edit Menu button instead, then launching the design editor from the quick insert screen.
send a link where i can see this and i can tell you how to fix it.
chris4754
It's here
I'm using whatever comes with Powerstore, I'm not aware what specific editor it is
The site is index.php
chris4754
Solved-kinda
This bevaviour happened when I was using the "Purple" template. I've switched to "Default" and now it works fine
I'm not able to reproduce the issue using the purple theme, if you have the problem again, let me know and i will take a look, it's probably a small edit to the css, but i would need to see the problem to track it down.
