3 small questions about eCart
Thread begun 7/29/2009 9:10 am by info374483 | Last modified 7/29/2009 10:08 am by Ray Borduin | 1826 views | 1 replies |
info374483
I have questions on the eCart setup for the checkout wizard.
1. Is is better to set up the checkout process remotely versus locally? Also how hard would that be to do that. Which is easier to setup 2Checkout, WorldPay, Authorize.net?
2. I would be setting up using UPS realtime, so I know I need to create a UPS account to get an XML access key, correct? What else would I need.
3. If I do setup with realtime, when UPS decides to change their rates, how do we update the site to reflect thier new rates? Or do we do anything at all. Because I heard that if UPS changes their rates then our website will be reflecting the wrong shipping amount.
1) Use authorize.net AIM... local checkout. Of your options that is the most common and easiest.
2) I think they give you a meter number and access key. Just sign up for an account and they will provide you with what you need.
3) Your website rates will update with the UPS rate automatically, that is why you use the service
