Remove space between two words
Thread begun 4/24/2012 5:38 am by randyw2394710 | Last modified 5/29/2012 8:30 am by Jason Byrnes | 2458 views | 5 replies |
randyw2394710
In the navigation I would like to remove the space in between two words in the contentpagename
For instance home page.php needs to be homepage.php
Preferably dynamically thanks
use the str_replace function.
str_replace(" ", "", "home page.php")
if you provide the code that is outputting "home page.php" I can tell you how to add the str_replace function to it.
randyw2394710
hello here is what iam trying to do
<?php echo $row_WADApg1_gallery_images["Gallery"]; ?>
echos out Print Media
i would like to be PrintMedia
str_replace(" ", "", "Print Media")
Ian S
str_replace(" ", "", $row_WADApg1_gallery_images["Gallery"]);
Cheers
Ian
randyw2394710
Will this echo the Colomn in gallery
<?php echo str_replace(" ", "", $row_WADApg1_gallery_images["Gallery"]); ?>
it will echo the Gallery column from the WADApg1_gallery_images recordset, and will use the str_replace function to remove any blank spaces.
