tTag.toUpperCase is not a function
Thread begun 4/22/2012 10:53 pm by Lee Firth | Last modified 4/24/2012 8:44 am by Jason Byrnes | 2539 views | 3 replies |
Lee Firth
Every time I add content to PowerCMS in Dreamweaver (WebAssist -> CMS -> Add Content to PowerCMS) I get the following error:
Error in insertToTable:
TypeError: tTag.toUpperCase is not a function
This happens right at the end of the process. The content seems to load in the database OK so at the moment it's just annoying.
What version of power CMS Builder do you have installed?
i believe this was an issue that happened in earlier versions of Design Extender and is corrected in Design Extender 1.0.3. Are you using the stand alone Power CMS Builder of the Power CMS Builder in Design Extender?
Lee Firth
I am using the latest version of Design Extender 1.03
Did you install another extension after installing Design Extender?
Design Extender should be the last extension that you install.
try uninstalling design Extender, then deleting the dreamweaver cache file:
and reinstalling Design Extender.
