Recordset emails not arriving
Thread begun 4/21/2012 12:18 pm by john70964 | Last modified 4/23/2012 12:06 pm by Jason Byrnes | 5272 views | 15 replies |
john70964
I have a contact form with a text box for email addresses.
The box is dynamically connect to a database
The recordset shows correct records on test but
The records do not show in the box and the recordset emails do not arrive.
If I place an email address in the box this arrives correctly.
I wonder if this code shows the problem
Thanks for any help
John
if (ValidatedField('email','email')) {
if ((strpos((",".ValidatedField("email","email").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Full_Name_ServerError">Please enter your name</span>
<?php //WAFV_Conditional email.php email(1:)
</div>
</div>
</div>
</div>
</div>
<div class="lineGroup">
<div class="fullColumnGroup">
<label for="Email_Address" class="sublabel" > Email<span class="requiredIndicator">&nbsp;*</span></label>
<div class="errorGroup">
<div class="fieldPair">
<div class="fieldGroup"> <span id="Email_Address_Spry">
<input id="Email_Address" name="Email_Address" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("email","Email_Address"):"")); ?>" class="formTextfield_Large" tabindex="2" onblur="hideServerError('Email_Address_ServerError');"/>
<span class="textfieldInvalidFormatMsg">Invalid format.</span><span class="textfieldRequiredMsg">Please enter a full email address</span> </span>
if ((strpos((",".ValidatedField("email","email").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Email_Address_ServerError">Please enter a full email address</span>
<?php //WAFV_Conditional email.php email(2:)
</div>
</div>
</div>
</div>
</div>
john70964
Entry Deleted
john70964
Being quite new to php and reading about pear email it occours to me perhaps I am doing this all wrong.
I am at the moment trying to send my form via my windows2003 server and I wonder if it must go via a php server....
My windows server does require a password.
I am working on my local PC localhost
I'm not sure i understand the issue correctly, you say that the email address text box is supposed to get it's value from a recordset? The initial value of the text box is not configured to use a recordset.
you then say if you fill in the text box it works...
since it works if you fill in the text box, i am confused by your last message questioning the Email server, if it works by filling in the text box, the email server you are using should be fine.
john70964
Thank Jason
I am sorry to be confusing you.
I want the email to go to a number of addresses.
When I look at the headings in the attached image
the email is FROM one address and the
TO is from a recordset.
I wonder is my understanding incorrect? Should the recordset be where it is in the TO field.
I am attaching and image of the UE and the code for the page.
click the to button to go to advanced to settings, this is where you can select to use a recordset loop.
john70964
I am assuming advanced is the Advanced in a recordset.
The recordset tests OK and the correct records show.
no, assumption is incorrect.
in the Universal Email behavior, click the "To" button to open the "Advanced To address" settings. This will allow you to select to use a recordset loop for the to address.
john70964
Thanks Jason
Getting somewhere now.
The required emails arrived!
I could not see the Advanced To address setting but completed the form as per image which seems to work.
In this case the Name Box seems not to be required?
The comments do not arrive in the email did I do something wrong?
The form in your screen shot is the advanced to options screen.
do you mean the Name form element? how is validation applied to the name form element, send a copy of the original php page in a zip archive.
how did you set the email body options? did you select to create a file for the email? I have no way of knowing whether you did something wrong or not. I have now way of know what settings you used to determine if they are wrong or right...
