Captcha not validating
Thread begun 4/20/2012 1:50 pm by johna1964 | Last modified 4/20/2012 2:13 pm by johna1964 | 1435 views | 2 replies |
johna1964
Original Captcha code worked perfectly:
<img src="../webassist/captcha/wavt_captchasecurityimages.php?field=Security_Code&noisefreq=15&noisecolor=060606&gridcolor=080808&font=fonts/MOM_T___.TTF&textcolor=040404" alt="Security Code" class="Captcha">
When I used the Captcha interface to add the refresh feature it no longer passes validation
<img id="capt1" src="../webassist/captcha/wavt_captchasecurityimages.php?width=200&height=30&field=Security_Code_1&bgcolor=FFFFFF&transparent=0&bgimage=&gridfreq=20&gridcolor=080808&gridorder=behind&noisefreq=15&noisecolor=060606&noiseorder=behind&characters=5&charheight=&font=fonts/MOM_T___.TTF&textcolor=040404" alt="security code" width="200" height="30" /><img src="../webassist/captcha/images/refresh.png" height="18" onclick="document.getElementById('capt1').src+='&ref=1'" />
Can you let me know what I need to do to correct this...
Thank you!!
johna1964
in the original, the cap[tcha session is named captcha_Security_Code, the session is named bassed on the field variable in the captcha image string:
field=Security_Code
the new one has a different value:
so the captcha session is named "captcha_Security_Code_1"
to fix it, change:
field=Security_Code
johna1964
Hi Jason,
I vaguely remember a similar - looked all over... couldn't find it.
Thank you for the quick reply and solution!
johns1964
