Use Data as column header in table?
Thread begun 4/19/2012 10:27 am by gary.brett434358 | Last modified 4/26/2012 4:39 am by gary.brett434358 | 838 views | 2 replies |
gary.brett434358
Hi there, I have created a DA page to show results of a small table containing Name,Month, Cases as such:
<table border="1" cellpadding="1" cellspacing="1">
<thead>
<tr>
<th scope="col">Name</th>
<th scope="col">Month</th>
<th scope="col">Cases</th>
</tr>
</thead>
<?php do { ?>
<tbody>
<tr>
<td><?php echo $row_rsChart2['ContactFullName']; ?></td>
<td><?php echo $row_rsChart2['Month']; ?></td>
<td><?php echo $row_rsChart2['Cases']; ?></td>
</tr>
</tbody>
<?php } while ($row_rsChart2 = mysql_fetch_assoc($rsChart2)); ?>
</table>
Is it possible I could use the month columns as a header,displaying Jan, Feb, March etc from left to right in column header and cases for each month as data?
Jan - Feb - Mar
User1 100 47 89
user2 86 67 134
With the default layout it displays as:
Name - Month - Cases
User1 Jan 100
User1 Feb 47
User2 86 67
Any advice much appreciated..
regards
this would require hand coding to achieve and is not supported.
you would need to set the recordset to order by the month
Then in the repeat region add code to set a variable that contains the current month and create the first header.
on writing the next record, compare the month stored in the variable to see if they are the same or different. if different, crete a new heading and reset the variable value.
gary.brett434358
Thanks Jason, as I thought way above my expertise, but I may have a crack anyway.
Cheers
