Captha not working
Thread begun 4/19/2012 10:15 am by jo271221 | Last modified 5/18/2012 4:04 pm by jo271221 | 4537 views | 8 replies |
jo271221
Captha not working
The captcha is not working on this page
Become_A_Dealer.php
please send a copy of the page.
jo271221
Here is a copy of the page
in the LE server validation, you have set it to compare the $_SESSION['captcha_Security_Code_1'] variable, to the $_SESSION['captcha_Security_Code_1'] variable.
it should be configured to compare the $_POST['Security_Code_1'] variable to the $_SESSION['captcha_Security_Code_1'] variable.
jo271221
Catpcha Help
Thanks - for some reason I could not find the helpful info on this page when I posted.
form-toolkit/
Now my registration form returns to the Users Registration if the captcha is not completed but it does not retain the entered information. Is it suppose to retain the entered info in the form so that the user does not have to re-enter? Thanks!
users_Registration.php
you need to set the initial value for each of the form elements to use the corresponding Validated entries binding.
in the form toolkit help, see the "Maintaining form data when validations fail" section for more details.
wa_fv_22.html
jo271221
not submitting at all
I messed something up, now the form is not submitting at all, refreshes the page without inserting or retaining.
for the initial value of the form elements, you are using the bindings from the form collection, you should be using the bindings from the validated entries collection.
it could be a php error preventing the form from submitting.
add the following code at line 1:
error_reporting
(E_ALL);
jo271221
works great
Thanks - I had a backup of my form so I just started over and it works great!
