Unique Validation triggers error if field is left blank
Thread begun 4/19/2012 8:32 am by Ian S | Last modified 4/20/2012 10:22 am by Ian S | 2699 views | 4 replies |
Ian S
I am currently putting a page together with a couple of form fields on.
Both fields are required, and the first field needs to be unique.
if (isset($_POST["BT_Create"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_pluginnew_788_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["friendlyname"]))?$_POST["friendlyname"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["filename"]))?$_POST["filename"]:"") . "",true,2);
$WAFV_Errors .= WAValidateUnique("webcatdb",$webcatdb,$database_webcatdb,"plugins","plugin_id","none,none,NULL","0","plugin_name","',none,''","".(((isset($_POST["friendlyname"]))?$_POST["friendlyname"]:"")) ."",true,3);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"pluginnew_788");
I then have two error messages next to the friendlyname field. These are wrapped in Show If statements.
if (ValidatedField('pluginnew_788','pluginnew_788')) {
if ((strpos((",".ValidatedField("pluginnew_788","pluginnew_788").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="texterror">Please enter a friendly name for this plugin.</span>
<?php //WAFV_Conditional pluginnew.php pluginnew_788(1:)
if ((strpos((",".ValidatedField("pluginnew_788","pluginnew_788").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
<span class="texterror">A plugin with this name already exists.
<?php //WAFV_Conditional pluginnew.php pluginnew_788(3:)
My problem seems to be that if the friendlyname field is left blank, the Unique validation error triggers and is shown aswell as the required error message.
Is there a way to stop the Unique validation error showing if the field is left blank, and only show the 'required' error?
Cheers
Ian
It sounds like there is an empty record in the plugin_name column of your database that is triggering the Unique validation to fail if the field is left blank.
the unique validation error will only show if that validation has failed. The required validation wont trigger it to show. so it must be finding a blank value in the database that is triggering it.
make sure there are no blanks in the plugin_name column
Ian S
Thanks Jason,
Yes, I did think that but the the table is empty. I have truncated it to make sure.
Very strange!
hmmm, ok, try changing this line:
if ((strpos((",".ValidatedField("pluginnew_788","pluginnew_788").","), "," . "3" . ",") !== false || "3" == "") && !(strpos((",".ValidatedField("pluginnew_788","pluginnew_788").","), "," . "1" . ",") !== false || "1" == ""))  {
Ian S
Thanks Jason,
Yes, that does get around the problem!
I can work with that for now.
Thanks again.
Ian
