PowerGallery in iFrame is overflowing
Thread begun 4/18/2012 1:28 pm by kim.dewindt425982 | Last modified 5/03/2013 1:25 pm by Jason Byrnes | 3135 views | 5 replies |
kim.dewindt425982
I'm trying to use a Gallery in an iFrame but the width is overflowing about 40-50 pixels. Here's the link:
photoGalleries.htm
I've set the width of the iFrame to 100%, played with heights and widths of the full-size images, can't find any way in the settings of the Grid + Fullsize design to change the width of the fullsize image wrapper.
Is there a way to do this?
(The width of the space/page I'd like to fit this Gallery into is about 780 pixels)
thanks,
Kim
MEge79917144
Power Gallery does not fit into iFrame
I have the same issue - but my iFrame space is is more like 625 pixels in an Editable Region. I found a post on going to flow, themes. etc. and resetting the width (in percentages) and tried a number of widths, but the result was always the same overflow.
I am thinking of getting rid of the right column, but even so I will only have about 850px width to work with...
Was there a resolution to this problems -- doesn't look like it because Kim's link above does not work.
Thank you,
Marietta
pleases send a link where i can see the problem.
MEge79917144
http://www.spectracomp.com/testsite/superiorplasticproducts/photogallerymain.php
It is in my root folder, as is the gallery folder.
I sized my original images to 900px X 600px @ 300dpi, assuming PG would resize and optimize. Also, it is currently in an editable region...should I just set it up in the maitable, or create a div for it, or eliminate the right column and get it to fit in the middle and right cells?
Are you using Power Gallery 2?
in power gallery 2 on the chose design page, you can edit the design, when editing the design, you can set the size for the images.
you set the large image size to be a size to fit in the iframe
also, the iframe style tag:
style="width:100%; height=900px;
should be:
style="width:100%; height:900px;
