Framework file not found:
Thread begun 4/16/2012 9:57 am by jeff382039 | Last modified 4/16/2012 1:27 pm by Jason Byrnes | 1575 views | 1 replies |
jeff382039
I have framework present, and working fine, no extra special coding, just the framework include. It works fantastic on my local server and a few other servers, however when i try to use it on a specific host i get the following error (error reporting turned on):
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(ics) is not within the allowed path(s): (d:\webs\) in D:\webs\boul35\webassist\framework\framework.php on line 28
Framework file not found: ics/social.php
What i am wondering is there a way to set the "open_basedir" (in php not the ini) to the proper directory or unrestrict it using the info above so this all works? If so what should the proper path be?
Cheers,
Jeff
the open base dir restriction cannot be turned of from the php page, it can only be turned of from the php.ini file
contact the host to have them modify the php.ini file to include the ics folder in the allowed paths.
