Ecart Checkout not opening
Thread begun 4/15/2012 11:42 pm by ColorHunger | Last modified 4/16/2012 12:28 pm by Jason Byrnes | 3857 views | 7 replies |
ColorHunger
Hello, iv search for the answer but have not found any solutions to my problem.. i have set up the ecart and checkout pages. Items ARE being shown in the ecart when added and the redirects ARE pointing to the checkout page. but when you click checkout it just reloads the cart, the checkout is not recognizing anything in the cart.. i tested this by changing the checkout redirect if cart empty to another page and when checkout is clicked it redirected it to that page.. please help.. the website is live, ArtworkBungalow.com.
please send a copy of the cart page and the checkout page in a zip archive so i can take a look at the code.
ColorHunger
bead; radyhem
ok thank you! attached are the files
on the checkout page, the code before the doctype tag is slightly out of order.
the code:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
?><?php require_once( "webassist/security_assist/helper_php.php" ); ?>
if ($eCart1->IsEmpty())     {
$eCart1->redirStr "cart.php";
$eCart1->cartAction "RedirectIfEmpty";
$eCart1
->GetContent();
?><?php
// WA eCart Redirect
if ($eCart1->redirStr != "")     {
header("Location: ".$eCart1->redirStr);
should be in this order:
//WA eCart Include
$eCart1
->GetContent();
ColorHunger
awesome thank you! i wuld have never figured that out... it goes to the checkout page but now its giving a error at the top of checkout page..
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/artbung/public_html/checkout.php:2) in /home/artbung/public_html/WA_eCart/WA_eCart_Definition_PHP.php on line 465
this error is caused by blank lines between php code blocks, the error is saying the blank line is at line 1 or 2.
see the following post for more details:
showthread.php?t=19285
ColorHunger
awesome! that worked. but now the checkout page is not going to the confirm page, it goes back to the view cart page. but it is loading the data from the checkout page into the order database.
im guessing to replace the same code you told me to do on the checkout page?
(YUP! that worked, just switched the code around on the confirm page! thanks again for all the help)
the key is to make sure this code block:
$eCart1
->GetContent();
is just after this one:
//WA eCart Include
like this:
//WA eCart Include
$eCart1
->GetContent();
