Disable login to all users
Thread begun 4/12/2012 9:55 pm by Paul | Last modified 4/16/2012 6:50 am by Jason Byrnes | 2657 views | 3 replies |
PaulBeta Tester
I have a login page created with SA, used by registered site users.
I would like to disable and enable the login (globally) by using a recordset as a trigger, where if empty the login remains enabled. The recordset looks at a separate mysql table which has a simple '0' & '1' switch that is updated dynamically in the admin area.
If the login fails because the recordset returns an empty row (the lock is enabled), the user is directed to a landing page explaining the event.
This however is causing the user to redirect back to the login page after submitting their credentials.
Would be interested to hear alternative methods to achieve this functionality?
create the recordset that returns the lock value, then create an if statement that uses the header function to redirect to another page if the value is 0, make sure this code comes before the security assist authenticate user code:
if($row_recordsetName['lockColumn'] == "0") {
header("Location: loginlocked.php");
    exit;
PaulBeta Tester
Thanks Jason.
A perfect solution.
you're welcome.
