Adding more product options
Thread begun 4/12/2012 4:58 pm by phil107723 | Last modified 4/16/2012 9:07 am by Jason Byrnes | 1905 views | 3 replies |
phil107723
Hi
I'm wanting to add more product options to my existing ecommerce website. I have worked my way through this tutorial product_options.php which is great and the your free database download very helpful . But I'm stuck on what kind of information to put in certain tables.
I have an item for sale at $200 at size 350mm the options are size 400mm for an extra $50, size 450mm for an extra $75 and another 2 sizes.
I have read this:
ecommerce-database/
but it didn't help.
So a product called Muffler1, code ADR001, that has the price $200 options 400mm for extra $50, 450mm for extra $75 what information would I enter into the tables on the database.
Table: optiongroups -OptionGroupID, OptionGroupName
Table: option - OptionID, OptionGroupID, OptionName
Table: productptions - ProductOptionID, ProductID, OptionID, OptionGroupID, OptionPriceIncrement
Table: productcategory - CategoryID, CategoryName
Have I said I think you're wonderful.
Phil
the optiongroups table defines that types of options you will offer, create a new record and set the OptionGroupName to "Size", the OptionGroupID will automaticly be assigned a number, if it is the first record, the number will be set to 1:
optiongroups:
| OptionGroupID | OptionGroupName |
| 1 | Size |
the options table defines the options that belong to a group, create a new record for each size option, set the OptionGroupID to use the number for the size option in the optiongroups table, and the OptionName to the name of the size:
options:
| OptionID | OptionGroupID | OptionName |
| 1 | 1 | 350mm |
| 2 | 1 | 400mm |
| 3 | 1 | 450mm |
the productptions table assigns the options to the product. the ProductOptionID is an auto inclrement column and will automaticly get a value.
the ProductID column should be the ID for the products, it relates to the products.ProductId
the OptionID column is the ID for the option from the options.OptionId column
the OptionGroupID is the ID of the optiongroup from the optionsgroups.OptionGroupID
the OptionPriceIncrement defines how much more the option will cost for that product
this is an example if the ID of the product is 1923
productptions:
| ProductOptionID | ProductID | OptionID | OptionGroupID | OptionPriceIncrement |
| 1 | 1923 | 1 | 1 | |
| 2 | 1923 | 2 | 1 | 50 |
| 3 | 1923 | 3 | 1 | 75 |
phil107723
Thanks for that.I had that right but I'd chosen rsSizeLookuo instead of rsSize for my select list which gave me my problem.
I was going through to see why the price increment wasn't adding to my cart when I found this back in the ecart object
Instead of [Price]+[sizePriceInc] it reverts to this [Price] +[size]PriceInc and the same thing for this [Price]+[sizePriceInc] * [Quantity] it reverts to this ([Price]+[size]PriceInc) * [Quantity]
I've just changed the column from sizePriceInc to SizePriceInc and in the add to cart column bindings.
But the price increase still isn't adding to the cart . And in fact the product detail page is now redirecting to itself.
This is my add to cart code:
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "TESTshop_cart.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsSingle_product) && $totalRows_rsSingle_product > 0) {
$row_rsSingle_product = WAEC_findRecordMySQL($rsSingle_product, "productID", $ATC_itemID);
if ($row_rsSingle_product) {
$ATC_itemName = "".$_POST["eCart1_1_Name_Add"] ."";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = "".$_POST["eCart1_1_Price_Add"] ."";// column binding
$ATC_itemConfig = "".$_POST["eCart1_1_Config_Add"] ."";// column binding
$ATC_itemlength = "".$_POST["eCart1_1_length_Add"] ."";// column binding
$ATC_itemInlet = "".$_POST["eCart1_1_Inlet_Add"] ."";// column binding
$ATC_itemImage = "".$_POST["eCart1_1_Image_Add"] ."";// column binding
$ATC_itemFourInchOption = floatval("".$_POST["eCart1_1_FourInchOption_Add"] ."");// column binding
$ATC_itemsize = "".$row_rsSizeLookup['OptionName'] ."";// column binding
$ATC_itemSizePriceInc = floatval("".$row_rsSizeLookup['OptionPriceincrement'] ."");// column binding
mysql_data_seek($rsSingle_product, 0);
$row_rsSingle_product = mysql_fetch_assoc($rsSingle_product);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemConfig, $ATC_itemlength, $ATC_itemInlet, $ATC_itemImage, $ATC_itemFourInchOption, $ATC_itemsize, $ATC_itemSizePriceInc);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
What am I doing wrong?
Phil
