Way to insert and edit
Thread begun 4/11/2012 2:33 pm by h150477 | Last modified 5/07/2012 6:46 am by h150477 | 5134 views | 11 replies |
h150477
I have an insert record form which has quite a lot of validation and hide / show fields on it.
It works as expected. I also need to provide an update record form for the same data. Is it practical to use a copy of this form to show the existing data in the record and apply an update record server behavior to it without having to enter all the validations again.
The problem as I see it is that I usually bind the date from the record that I am updating to the form fields during edit, when using a different validation system to security assist.
However, the fields need to be bound to the Webassist validation variables so that if a field does not validate, the data is re-displayed.
It seems that the same fields will need to be bound to two different variables which looks like it may not work.
So just how does one create an update record form and validate it?
see this thread for details;
showthread.php?t=1146
h150477
That does not answer my question, or if it does then I do not understand what it is saying.
First of all, what is meant by
"Pass a url parameter in your failed redirect for your server validations like: pagename?valid=false"
In my insert page, there is no redirect anywhere other than to itself on failure or on success to a page that displays the data, so why would I need one in an edit page?
I am using existing data to fill out my form initially from a stored recordset, a typical field opening value being :"<?php echo $row_eventset['club_organiser']; ?>" This comes from the field being bound to the recordset value, in this case 'club_organiser'.
Following the other thread, which states:
<?php echo(isset($_GET['valid'])?ValidatedField("page","field"):"yourdefault"); ?>
How do I translate this for my field value?
I can see that "yourdefault" could be "$row_eventset['club_organiser']"
What goes in ($_GET['valid'])?ValidatedField("page","field")?
Where does "page" come into the argument? Does this refer to a page that the form re-directs to after a successful update. If the form redirects to itself, is this required?
All in all, it makes little sense, and these server behaviours are supposed to be for beginners like me to use.
Can you give additional information?
you say:
the WebAssist validation variables you refer to come from the Server Validation Server Behavior.
In the Server Behaviors panel, you should have a server behavior named Server Validation
In the server validation server behavior, there is a setting for Failed redirect. set this to redirect to the same page, and pass a query string variable, so if the name of the page is:
updatePage.php
set the failed redirect to:
updatePage.php?valid=false
this would be:
<?php echo(isset($_GET['valid'])?ValidatedField("page","field"):$row_eventset['club_organiser']); ?>
the validated entries code for your page will be generated from the bindings panel.
Go to the bindings panel, and expand the validated entries collection, then add a validated entries binding to your page, this will show the correct validated entries code for your page as a starting point.
If you are unsure of how to modify that code for the desired result, post it hear and i will be happy to help.
h150477
Is this what you mean
Thanks Jason, but I still don't follow at all. When I make the changes suggested that all I get is a lot of uncorrectable syntax errors.
It looks to me like the only way to buid an edit page is to rewrite it all from the start, get it working and then add the validations.
Will do that and come back again if I'm stuck.
h150477
I now have a working update page with all the formatting requirements for each field shown on the page.
If you can edit two of the fields to show how the information stored in them can be retained, I should be able to follow and do the rest myself.
One field is the event expiry, chosen because its a drop down list - does one need to validate these?
The other is the event title - just to show the idea.
The file is uploaded.
you don't have any validation applied, so you only need to bind the fields to the corresponding column from the recordset.
for the title, select it in design view, in the property inspector, click the lightning bolt next to the initial value and select the title column from the eventset recordset.
for the select list, select it in design view, click the Dynamic button in the property inspector. Next to the Select Value Equal to option, click the lightning bolt and select the event date column from the eventset recordset.
h150477
Its a long time since I used design view for anything.
Both fields are already bound to their recordsets as you describe in the submitted file, and any attempt to do what you state produces an error message that confirms this.
Can I re-frame the questions Jason, as I did not express myself correctly.
I do need validation, but have not done so yet.
1. Can you insert the required validations for the title as shown next to it in the file and display the resultant code, together with the bindings required to retain its value after a failed validation.
2. Do list menus need validating as they always have a default value which should be correct. I usually never validate these drop down lists as mine always extract their values from an existing validated recordset.
1) You need to add the validation behavior.
I can show you the code for using either the recordset value or validated entries value after you have applied the validation behavior.
2) if you are sure the values wont change, then no you dont need to validate the select lists.
h150477
I added some validation to all the fields, though one in particular does seem to have an error. Thiis is the event_description field, which will not accept the following text:
Europes Biggest LT meeting.<br>
See the event link for more information.
Limited accomodation remaining so book early or camp
which I thought that it should.
However, the file is attached as a text file.
Hope that this is enough.
