Security rule logged in as owner
Thread begun 4/10/2012 7:11 pm by jo271221 | Last modified 4/11/2012 8:02 am by Jason Byrnes | 1248 views | 1 replies |
jo271221
I want to restrict updating unless the user is logged in as the owner on this page (and other update pages on this site)
update_event.php?eventid=96609
Plz see attached update, login and helper pages. - It is not uploading in IE, I will try FF
Thanks,
when you store the event in the database, you should have a column in the events table for the event owner.
in security assist, when a person logged in, their id is stored in a session, in the event owner column, store the ID of the logged in user.
On the update page, there will be a recordset used to display the current event, in this case, it is being filtered by the eventid querystring variable:
?eventid=96609
so the recordset SQL will look something like this:
SELECT * FROM events WHERE eventid = paramEventID
in the variables section:
type: integer
default value: -1
run time value: $_GET['eventid']
you will need to edit the recordset to include the the event owner column and compare it against the user ID session variable.
WHERE eventid = paramEventID AND eventOwner = paramUserID
new variable:
type: integer
default value: -1
run time value: $_SESSION['userID']
bear in mind that i don't know your database structure, or session variable names, so any code above is purely for example
