Saving Shipping choice when multiple options
Thread begun 4/10/2012 1:53 pm by Steve | Last modified 6/27/2013 11:49 am by Jason Byrnes | 6726 views | 13 replies |
Steve
Hello,
When you have multiple shipping values is there a plan to then set the Shipping Type selected so the Admin can then make sure they use the chosen shipping type?
For instance:
<form name="checkoutForm"  id="checkoutForm"  action="<?php echo $_SERVER["PHP_SELF"]; ?>" method="post">
<select name="shipSelect" id="shipSelect" onchange="document.getElementById('checkoutForm').submit()" >
<option value="<?php echo($groundShip); ?>" <?php if (!(strcmp($groundShip, $eCart1->GetShipping()))) {echo "selected=\"selected\"";} ?>>Ground $<?php echo($groundShip); ?></option>
<option value="<?php echo($twoDayAir); ?>" <?php if (!(strcmp($twoDayAir, $eCart1->GetShipping()))) {echo "selected=\"selected\"";} ?>>2nd Day Air $<?php echo($twoDayAir); ?></option>
</select>
If there is not some pre-determined eCart procedures I will be taking the $groundShip and $twoDayAir vars, looking to see which is availble in the $_Post then setting that as a Session value.
Next it looks like the 'eCart Store Details in Database' and eCart Store Summary in Database" lack a field value for accepting the designation of the selected Shipping Type so one of these will need to be manually tweaked to accept the Insert or Update procedures.
Then the Database will need to be adjusted to have a table field that will accept these incoming values.
Is this the correct flow or is there something already in place I am missing?
Thanks in advance!
you will needt o add a column to the orders table for the ship type, save the selected ship type in a session variable, then update the Store Order Summary behavior to bind the ship type column of the orders table to the ship type session you create.
Steve
Thanks Jason.
Steve
Hello,
Finally getting around to putting the shipping type in place on this cart. The suggested methods were implemented but do not work as the value in the select list is the numeric value returned from the shipper not the visual reference.
<?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->GetShipping()); ?>
</select>
I have the session value being saved and inserted but how to get the title rather then value from a select list to put in the session?
<?php // added 6_26_13 to save off shipping method
if($_SERVER["REQUEST_METHOD"] == "POST") {
$_SESSION["eCartCheckoutForm_shipping_method"] = "".((isset($_POST["shipSelect"]))?$_POST["shipSelect"]:"") ."";
add a hidden element to the form, and add a javascript on change event to the select list to save the label of the select to the hidden element
onChange="document.form1.hiddenfield.value = document.form1. shipSelect[document.form1. shipSelect.selectedIndex].text"
This example assumes the hidden element is named hiddenfield and the form is named form1
add another set session value behavior to store the hidden element in a session:
$_SESSION["eCartCheckoutForm_shipping_method_label"] = "".((isset($_POST["hiddenfield"]))?$_POST["hiddenfield"]:"") ."";
and use the eCartCheckoutForm_shipping_method_label session to store the selected shipping method.
Steve
Hmmnnn, I just figured I could use this method :
if (isset($_POST['shipSelect']) && ($_POST['shipSelect']==$groundShip)) {
$_SESSION["eCartCheckoutForm_shipping_method"] = 'Ground';
} elseif (isset($_POST['shipSelect']) && ($_POST['shipSelect']==$twoDayAir)) {
$_SESSION["eCartCheckoutForm_shipping_method"] = '2 Day Air';
I'll test my solution then use yours if it falis. Thanks for the fast reply.
Steve
Niether method worked :-(
Using your method I need append an already existing onChange trigger:
(note the form is called "ecart_checkout_form"
<select name="shipSelect" id="shipSelect" onchange="document.getElementById('checkoutForm').submit(); document.ecart_checkout_form.shipping_method.value = document.ecart_checkout_form. shipSelect[document.ecart_checkout_form. shipSelect.selectedIndex].text">
The hidden field is named "shipping_method":
<input type="hidden" name="shipping_method" id="shipping_method" value="<?php echo ((isset($_SESSION["eCartCheckoutForm_shipping_method"]))?$_SESSION["eCartCheckoutForm_shipping_method"]:"") ?>" />
and setting the session is as follows referencing the hidden field name:
  $_SESSION["eCartCheckoutForm_shipping_method"] = "".((isset($_POST["shipping_method"]))?$_POST["shipping_method"]:"") ."";
I use a print_r ($_SESSION); on the confirm page and only see the hidden value still supporting the numeric cost of the selected shipping.
I'll keep studying this but can not currently see the problem other than the JS that should be getting the label value?
1) the on change:
should be reversed:
onchange="document.ecart_checkout_form.shipping_method.value = document.ecart_checkout_form. shipSelect[document.ecart_checkout_form. shipSelect.selectedIndex].text; document.getElementById('checkoutForm').submit(); "
2) The shipping method session should still have the number, the number needs to be passed to the shipping lookup, you need to set another session to capture the label
so you have one session that captures the number that is passed, and another session that is capturing the label.
Steve
Message sent
Originally Said By: Steve
  Message sent
