Confirm Page with Warning: mysql_select_db() expects parameter 2 to be resource, null
Thread begun 4/10/2012 1:25 pm by ori382079 | Last modified 7/12/2018 8:55 am by Ray Borduin | 100423 views | 13 replies |
ori382079
Received the following error message in confirm page:
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /customers/d/6/8/sapphire-wardrobes.com/httpd.www/confirm.php on line 37 Warning: mysql_query() expects parameter 2 to be resource, null given in /customers/d/6/8/sapphire-wardrobes.com/httpd.www/confirm.php on line 71
I have checked every thing possible and even compared the page with similar pages on other sites but could not identify where the problem is located. This page was previously working well and just about to tidy up and deliver it, this error starts coming up.
Please find attached the codes.
in the code you provide, i do not see a require once line to add the connection file that defines the connection to the database:
should look something like:
<?php require_once('Connections/sapphire_wardro.php'); ?>
Pardall1955
Same Problem
I have the same problem, but it works on the localhost but not in the server on the web.
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /home/qcc/public_html/WA_SecurityAssist/Helper_PHP.php on line 14
Warning: mysql_query() expects parameter 2 to be resource, null given in /home/qcc/public_html/WA_SecurityAssist/Helper_PHP.php on line 20
here is my login code:
<?php require_once('Connections/connQCC1.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if(isset($_POST["LogIn_x"])){
$WA_Auth_Parameter = array(
"connection" => $connQCC1,
"database" => $database_connQCC1,
"tableName" => "members",
"columns" => explode($WA_Auth_Separator,"mEmail".$WA_Auth_Separator."mPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"") ."".$WA_Auth_Separator."".((isset($_POST["userpassword"]))?$_POST["userpassword"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"mID".$WA_Auth_Separator."mUserLevel"),
"sessionNames" => explode($WA_Auth_Separator,"mID".$WA_Auth_Separator."mUserLevel"),
"successRedirect" => "A958D04I990N/a-index.php",
"failRedirect" => "EmailPW.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
before uploading to the live server, you need to update the database connection file with the correct details for connecting to the remote server.
Kenny
same problem pls help
I run d same error in my live server .. here is the php
//session_start();
include "authuser.php";
<?php require_once('Connections/config.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_rsInfo = "-1";
if (isset($_SESSION['user'])) {
$colname_rsInfo = $_SESSION['user'];
mysql_select_db($database_config, $config);
$query_rsInfo = sprintf("SELECT Firstname, Lastname, Othername, email, Account_ID, `currency`, image FROM accounts WHERE Account_ID = %s", GetSQLValueString($colname_rsInfo, "text"));
$rsInfo = mysql_query($query_rsInfo, $config) or die(mysql_error());
$row_rsInfo = mysql_fetch_assoc($rsInfo);
$totalRows_rsInfo = mysql_num_rows($rsInfo);
$colname_rsAcct = "-1";
$colname_rsAcct = $_SESSION['user'];
$query_rsAcct = sprintf("SELECT * FROM accdetail WHERE Account_ID = %s", GetSQLValueString($colname_rsAcct, "text"));
$rsAcct = mysql_query($query_rsAcct, $config) or die(mysql_error());
$row_rsAcct = mysql_fetch_assoc($rsAcct);
$totalRows_rsAcct = mysql_num_rows($rsAcct);
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>RBS | The Royal Bank of Scotland | Personal, Private, Business &amp; Corporate Banking == Accounts Summary</title>
<style type="text/css">
body {
background-color: #FFFFFF;
margin-left: 0px;
margin-top: 0px;
margin-right: 0px;
margin-bottom: 0px;
.style13 {
font-family: Arial, Helvetica, sans-serif;
font-size: 12px;
color: #FFFFFF;
</style>
<link href="images/main.css" rel="stylesheet" type="text/css" />
.apps_form {background-color:#919191;
font-family:Verdana, Arial, Helvetica, sans-serif;
font-size:9pt;
text-decoration:none;
a:link {
color: #FF0000;
text-decoration: none;
a:visited {
color: #0099CC;
a:hover {
color: #FFFF00;
a:active {
color: #993366;
.style59 {font-size: 11px}
.style59 {font-size:12px;
font-weight:bold;
.style60 {color: #000000}
.style60 { font-family: Arial, "Engravers MT", DilleniaUPC;
font-size: 15px;
color: #FF0000;
font-weight: bold;
body,td,th {
color: #000000;
.style66 { color: #000000;
font-style: italic;
font-weight: bold;
.style64 {font-family: Arial, "Engravers MT", DilleniaUPC; font-size: 12px; color: #000000; font-weight: bold; }
.style68 {
color: #FF3300;
font-weight: bold;
.style72 {color: #000000; font-family: "Courier New", Courier, monospace; font-size: 16; font-weight: bold; }
.style73 {font-size: 16}
.style74 {
color: #FF0000;
font-weight: bold;
.style75 {
color: #FF4D4D;
font-weight: bold;
.style76 {color: #FF0000}
.style79 {
font-size: 14px;
color: #FFFFFF;
font-style: italic;
.style86 {color: #003366; font-weight: bold; }
.style87 {
color: #CC3333;
font-weight: bold;
.style88 {
color: #CC3300;
font-weight: bold;
.style90 {color: #990000; font-weight: bold; font-size: 14px; font-style: italic; }
.style91 {
color: #FF3366;
font-weight: bold;
.style92 {
color: #990000;
font-style: italic;
</style>
function MM_openBrWindow(theURL,winName,features) { //v2.0
window.open(theURL,winName,features);
</script>
</head>
<body>
<table width="1014" height="971" border="0" align="center" cellpadding="0" cellspacing="0">
<!--DWLayoutTable-->
<tr background="images/bglogo.png">
<td height="245" colspan="4" valign="top"><table width="99%" height="229" border="0" cellpadding="0" cellspacing="0">
<tr>
<td width="422" height="80" valign="top" bgcolor="#284B7E"><img src="images/logo.png" width="260" height="80" /></td>
<td colspan="2" align="right" valign="middle" bgcolor="#284B7E" class="style13"><!--DWLayoutEmptyCell-->&nbsp;</td>
</tr>
<tr>
<td height="147" colspan="2" valign="top"><p>&nbsp;</p>
<p>&nbsp;</p>
<p>&nbsp;</p> <p>&nbsp;</p></td>
<td width="557" valign="top"><div align="right">
<p><br />
<br />
<img src="images/bann.png" width="144" height="82" /></p>
</div></td>
</tr>
<tr>
<td height="0"></td>
<td></td>
<td></td>
</tr>
<tr>
<td height="2"></td>
<td width="32"></td>
<td></td>
</tr>
</table> </td>
<td width="1"></td>
</tr>
<tr>
<td height="114" colspan="4" align="center" valign="middle"><table width="937" border="0" align="center" bgcolor="#FFFAE4">
<tr align="center" valign="middle">
<td width="133" height="85"><img src="admin/images/transfer.gif" width="67" height="67" border="0" usemap="#Map2" /></td>
<td width="133"><img src="admin/images/bp_main.gif" width="67" height="67" border="0" usemap="#Map3" /></td>
<td width="133"><img src="admin/images/em_main.gif" width="67" height="67" border="0" usemap="#Map5" />
<map name="Map5" id="Map5">
<area shape="rect" coords="2,2,64,64" href="#" onclick="MM_openBrWindow('secure_msg.php','','scrollbars=yes,width=700,height=700')" />
</map></td>
<td width="133"><img src="admin/images/upload.gif" width="67" height="67" border="0" usemap="#Map6" /></td>
<td width="172"><img src="admin/images/hp_main.gif" width="67" height="67" border="0" usemap="#Map4" /></td>
<td width="207"><img src="admin/images/ex_main.gif" width="67" height="67" border="0" usemap="#Map" /></td>
</tr>
</table> </td>
<td></td>
</tr>
<tr>
<td width="163" rowspan="3" align="center" valign="top"><p><img src="<?php echo $row_rsInfo['image']; ?>" width="118" height="135" /></p>
<p><?php echo $row_rsInfo['Account_ID']; ?></p>
<p><img src="images/myacct-my-pers-acct-pic.jpg" width="163" height="112" align="top" /></p>
<table width="161" border="0" align="center" bgcolor="#666666">
<tr>
<td height="33"><a href="my_accounts_details.php"><strong>My Account</strong></a></td>
</tr>
<tr>
<td height="41"><a href="transfer.php"><strong>Make transfer</strong></a></td>
</tr>
<tr>
<td height="39"><a href="#" onclick="MM_openBrWindow('services.php','','width=700,height=650')"><strong>PayBill</strong></a></td>
</tr>
<tr>
<td height="40"><a href="#" onclick="MM_openBrWindow('services.php','','width=700,height=650')"><strong>Change Profile</strong></a></td>
</tr>
<tr>
<td height="32"><a href="#" onclick="MM_openBrWindow('secure_msg.php','','scrollbars=yes,width=700,height=700')"><strong>Send mail</strong></a></td>
</tr>
<tr>
<td height="27">&nbsp;</td>
</tr>
<tr>
<td height="22">&nbsp;</td>
</tr>
</table> <p>&nbsp;</p></td>
<td width="559" height="35" align="center" valign="top"><div align="left">Welcome <strong><?php echo $row_rsInfo['Firstname']; ?> <?php echo $row_rsInfo['Othername']; ?> <?php echo $row_rsInfo['Lastname']; ?></strong></div></td>
<td width="281" valign="top"><div align="left">You are logged in as <span class="style92"><u><?php echo $row_rsInfo['Account_ID']; ?></u></span></div></td>
<td colspan="2" rowspan="3" align="center" valign="top"><!--DWLayoutEmptyCell-->&nbsp;</td>
</tr>
<tr>
<td height="385" colspan="2" align="center" valign="top"><div align="left">
<p><strong>Account Summary:</strong></p>
<table width="96%" height="374" align="center" cellpadding="4" cellspacing="2" bordercolor="#339999" bgcolor="#CCCCCC">
<tr bgcolor="#A4C2C2">
<th width="23%" scope="col"><span class="style59">Account Number </span></th>
<th width="19%" scope="col"><span class="style59">Account Type </span></th>
<th width="21%" scope="col"><span class="style59">Account Status </span></th>
<th colspan="2" scope="col"><div align="left"><span class="style59">Closing Balance <strong>(<span class="style91"><?php echo $row_rsAcct['currency3']; ?></span>)</strong></span></div></th>
</tr>
<tr>
<td height="53"><div align="center" class="style72"><?php echo $row_rsAcct['accnum']; ?></div></td>
<td><div align="center" class="style72"><?php echo $row_rsAcct['acctype']; ?></div></td>
<td><div align="center" class="style72"><?php echo $row_rsAcct['accstatus']; ?></div></td>
<td width="21%"><div align="center" class="style72">
<div align="center"><?php echo $row_rsAcct['ledgbal']; ?></div>
</div></td>
<td width="16%"><span class="style73"></span></td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td colspan="4">&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td colspan="4"><hr /></td>
<td>&nbsp;</td>
</tr>
<tr>
<td colspan="3"><div align="right"><span class="style60"><strong>Available Balance: </strong></span></div></td>
<td><div align="center"><?php echo $row_rsAcct['availbal']; ?> (<span class="style91"><?php echo $row_rsAcct['currency3']; ?></span>)</div></td>
<td><a href="transfer.php">Make transfer </a> </td>
</tr>
<tr>
<td>&nbsp;</td><u>
<td><div align="right" class="style74"><em>Summary</em></div></td>
<td><span class="style74"><em>of last transaction</em></span></td></u>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td><span class="style90">Your&nbsp;&nbsp;&nbsp;&nbsp; Previous </span></td>
<td><span class="style90">Transfer</span></td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td><span class="style86">Bank Name:</span></td>
<td><span class="style86">Bank Address</span></td>
<td><span class="style86">Account name:</span></td>
<td><span class="style86">Account number</span></td>
<td><span class="style86">Amount transfered</span></td>
</tr>
<tr>
<td><span class="style87"><?php echo $row_rsAcct['bankname']; ?></span></td>
<td><span class="style88"><?php echo $row_rsAcct['bankaddress']; ?></span></td>
<td><span class="style88"><?php echo $row_rsAcct['accnametrans']; ?></span></td>
<td><span class="style88"><?php echo $row_rsAcct['accnumtrans']; ?></span></td>
<td><span class="style88"><?php echo $row_rsAcct['amounttransfer']; ?></span></td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td><div align="center" class="style91"><?php echo $row_rsAcct['currency3']; ?></div></td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
<table width="96%" border="0" align="center" bgcolor="#FF6600">
<tr>
<td height="28" align="center" class="style60"><div align="center" class="style91"><span class="headingOneGrey">Next Of Kin:</span> <span class="bodytextAprBold"><em><?php echo $row_rsAcct['nextofkings']; ?></em></span></div></td>
</tr>
</table>
<hr />
<div align="right"><span class="style64">Your Email address is</span><span class="style66">:<span class="style76"><?php echo $row_rsInfo['email']; ?></span><br />
(Please note that all correspondent will be sent to this email address)</span></div>
</div> </td>
</tr>
<tr>
<td height="188" colspan="2" valign="top"><table width="645" border="1" align="center">
<tr>
<td width="137" height="157"><div align="center"><img src="images/anim_graph-4.gif" width="107" height="101" /></div></td>
<td width="271"><div align="center"><img src="images/fixed_mortgage_hp030608.gif" width="271" height="141" /></div></td>
<td colspan="2" valign="top"><img src="images/investments_tab_egg-geb.gif" width="215" height="153" /></td>
<td width="18">&nbsp;</td>
</tr>
<tr>
<td height="30"><div align="center"><u><span class="style68">Operation Highlight</span></u></div></td>
<td><div align="center" class="style74"><u>Exclusive Mortgage</u></div></td>
<td width="131"><div align="center" class="style75 style76"><u>Investment</u></div></td>
<td width="78"></td>
<td></td>
</tr>
</table> </td>
</tr>
<tr>
<td height="4"></td>
<td></td>
<td></td>
<td width="11"></td>
<td></td>
</tr>
</table>
<table width="983" height="27" align="center" bgcolor="#345585">
<tr>
<td width="975" height="21"><div align="center" class="style23 style79">Royal Bank of Scotland &copy;All right reserved</div></td>
</tr>
</table>
<map name="Map" id="Map">
<area shape="rect" coords="2,2,63,62" href="logout.php" />
</map>
<map name="Map2" id="Map2"><area shape="rect" coords="0,-1,66,66" href="transfer.php" />
</map>
<map name="Map3" id="Map3"><area shape="rect" coords="-1,-2,66,67" href="#" onclick="MM_openBrWindow('services.php','','width=700,height=650')" />
</map>
<map name="Map4" id="Map4"><area shape="rect" coords="-2,-4,67,69" href="#" onclick="MM_openBrWindow('services.php','','width=700,height=650')" />
</map>
<map name="Map6" id="Map6">
<area shape="rect" coords="-4,-8,71,66" href="#" onclick="MM_openBrWindow('plain.php','','width=700,height=650')" />
</map>
ERRORS ARE
Warning: mysql_select_db() expects parameter 2 to be resource, null given in /home/helpde82/public_html/RBS1/my_accounts_details.php on line 40
Warning: mysql_query() expects parameter 2 to be resource, null given in /home/helpde82/public_html/RBS1/my_accounts_details.php on line 42
the error means that the information in the Connections/config.php file for connecting to the MySQL Data base server is not correct.
you will need to edit that file and enter the correct details to connect to the MySQL server.
danielsebas
Same problem
Hi Jason, I have the same problem. I checked the connections for my local server and for the live server and they are correct.
Warning: mysql_select_db() expects parameter 2 to be resource, object given in /mailformatting_php.php on line 56
Warning: mysql_query() expects parameter 2 to be resource, object given in /mailformatting_php.php on line 94
send a copy of the page please.
brendan.rehman143550
Has this issues been resolved? I thought buying these tools again would save me time, but its been a headache just to get started.
This shouldn't be an issue in the current version. If you are having problems, please attach a copy of the page you are having issues with and I'll take a look to see what it might be.
