Recurring error
Thread begun 4/10/2012 8:03 am by gb261593 | Last modified 4/10/2012 11:02 am by gb261593 | 2664 views | 6 replies |
gb261593
Recurring error
I am using data search to produce a search form to extract data. I have been trying for some time to get it to work and each time get the same error so I have also tried with just a single search item and it fails in the same way. The error I get on the results page is
Call to undefined function setQueryBuilderSource() in /Applications/MAMP/htdocs/communitylinks/probono/admin/Search_Results.php on line 51
Line 51 is setQueryBuilderSource($query_rsList,$WADbSearch1,false);
I have used this before and it has worked fine. What am I doing wrong now.
I can supply as many more details as are needed.
Many thanks
most like the require once line to include the data assist search helper file is not in the correct order.
send a copy of your page in a zip archive so I can examine the code to advise on how to fix this issue.
gb261593
Thanks for such a quick reply. Zip file attached
move the following code from line 56 - 59:
//WA Database Search Include
require_once("../../WADbSearch/HelperPHP.php");
to line 1
gb261593
I've tried that and I now get the results page without any filter applied and 3 error lines:
Notice: Undefined variable: WADbSearch1 in /Applications/MAMP/htdocs/communitylinks/probono/admin/Search_Results.php on line 56
Notice: Trying to get property of non-object in /Applications/MAMP/htdocs/communitylinks/WADbSearch/HelperPHP.php on line 381
Notice: Trying to get property of non-object in /Applications/MAMP/htdocs/communitylinks/WADbSearch/HelperPHP.php on line 395
Line 56 is setQueryBuilderSource($query_rsList,$WADbSearch1,false);
381 is if ($QB->ObjectType == "WC") {
395 is else if ($QB->ObjectType == "OB") {
gb261593
I have found out what the problem and can fix it manually but I've no idea why the extension does it.
I have to move lines 56 -98 (in my Search_Results file) to the top of the page just after the connections line. It then worked fine.
Thanks for your help - a fix would be good!
