errors in path names
Thread began 4/10/2012 6:51 am by f.v.bragt428438 | Last modified 4/10/2012 8:22 am by Jason Byrnes | 818 views | 1 replies |
f.v.bragt428438
The php code generated by datassist does not work and leads to php errors. It turn out that
- include path names are generated which include directory names that do not exist on my PC or server (examples available). Manually changing it to the correct path names solves the issue.
- including php files through 'virtual' does not work, changing to include_once soles the issue
- error "Cannot redeclare class" because of duplicate lines of php code. Remoning the duplicate lines solves the issue.
Although the issue is listed under this forum, the first en second issue occur with many extensions.
I have deleted the cache files many times, and reinstalled extension etc. but no improvement.
Anyone knows how to fix this, or is it just a bug in the extensions?
Thanks,
Frans
