Captcha - Not case sensitive
Thread begun 4/10/2012 6:37 am by superpac250441 | Last modified 4/11/2012 7:38 am by Jason Byrnes | 6055 views | 7 replies |
superpac250441
Hi there,
I have a little problem with trying to make the captcha not case sensitive. On the place where it should be configured, it doesn't show the relevant checkbox - see photo.
Perhaps someone could give me the relevant code adjustments to sort this.
Many thanks
the code fix is to use strtolower(), send a copy of your page, and i can give the exact code to change.
superpac250441
Thanks Jason - Here you are attched
change:
$WAFV_Errors .= WAValidateLE($_SESSION['captcha_Security_Code_1'] . "",((isset($_POST["Security_Code_1"]))?$_POST["Security_Code_1"]:"") . "",true,7);
$WAFV_Errors .= WAValidateLE(strtolower($_SESSION['captcha_Security_Code_1']) . "",((isset($_POST["Security_Code_1"]))?strtolower($_POST["Security_Code_1"]):"") . "",true,7);
superpac250441
Perfect, thanks a million Jason!!
you're welcome.
superpac250441
Thanks again Jason. Do I assume that this will be sorted on next update??
yes, a bug has been logged so it can be fixed in a future upgrade.
