Insert and Display Date in U.S. Format (mm/dd/yy) - MySQL PHP
Thread begun 4/09/2012 9:06 am by Cactus Gary | Last modified 2/02/2017 8:35 am by Ray Borduin | 7953 views | 1 replies |
Cactus Gary
If you have a form field for entering a date in MM/DD/YY format but need to insert it into a MySQL database (which is YYYY/MM/DD format), place this code at the very top of your page to convert the date format so it will insert correctly. My form field name is "mydate" so change that to your field name. If you're using the WebAssist DatePicker, the field ID will be called something like: datepicker_1. Don't change or use the field ID. Use the field name.
if(isset($_POST['mydate']) && $_POST['mydate'] != "") {
$_POST['mydate'] = date("Y-m-d", strtotime($_POST['mydate']));
If you're retrieving the date from a MySQL database and need to display in MM/DD/YY format, use this code on your page where you want the date to appear:
<?php echo date("m/d/y", strtotime($row_MyRecordset['mydate'])); ?>
Of course, change the recordset name and field name to yours. You can also use the above code to populate the value of a form field if you're doing an update page.
Accumike
Code for UK / EU formats
If your form or datepicker uses UK / EU format date, then 4th February is returned as 2nd April.
Fix this by putting this code at the very top of your page:
<?php if(isset($_POST["mydate"])) $_POST["mydate"] = str_replace("/","-",$_POST["mydate"]); ?>
(change 'mydate' to the name in your form)
See this post for explanation: How to format DatePicker date to dd/mm/yyyy...
Thanks to everyone who pointed me in the right direction.
