No redirection to the cart display page after "add to cart" button clickk
Thread begun 4/09/2012 4:32 am by daniel.fleury436552 | Last modified 4/11/2012 8:38 am by Jason Byrnes | 2980 views | 5 replies |
daniel.fleury436552
Hi
In my "add to cart" button the behavior is set to redirect to the cart display page. After click the item is well added to the cart but the cart display page is not displayed and the product page is displayed again.
Strange because with a simple training eCart page all is fine but in my real pages the cart display page is not displayed after "add to cart". In both case I use the "Add to cart wizard". Any idea what should be wrong or where to check?
Of course the name of my cart display page is good ;-)
$ATC_RedirectAfter = "panier.php";
Thanks, Daniel
send a copy of the page with the add to cart button on it so I can examine the code.
daniel.fleury436552
Files
Hi, I send you somes files:
Two very similars pages with dynamic buttons :
- DynamicButton_OK.php, all is fine with this file, the redirection works
- DynamicButton_Bug.php, redirection no works and I'm unable to understand why
A only one static button page in a folder with template and eCart folder, if you need.
Thanks, Daniel
the problem is caused by a blank line between php code blocks at line 76:
remove that blank line between the code blocks:
daniel.fleury436552
Fantastic ! all is OK now :-)
Thanks for your help
you're welcome.
