"Welcome John Doe. View your Profile. Logout"
Thread begun 4/07/2012 9:28 am by elevy388997 | Last modified 4/09/2012 9:24 am by toms016390756 | 2286 views | 2 replies |
elevy388997Beta Tester
How would I go about making a login form that once they are logged in, doesn't show the form any more but a welcome message with options to view/update their profile or logout (then once logged out, it shows the login form again).
I figured it would be a series of Show Behaviors but I have never messed around with that. I tried searching for something like this but didn't really know what words to search for.
I was thinking about making the default login.php function as described then use the framework plug-in to place it in the appropriate area of my site template so it shows up site wide.
to show the users name, you will need to store it in a session variable. to do this, open the login page, go to the server behaviors panel and double click the Authenticate User server behavior. On the session variable tab, click the plus button and select the User First name and user last name columns.
You can then use the bindings for the first name and last name session variables to show them on your page along with the link tothe profile page
to show or hide areas of the page based on login state, use the security assist show region behavior (Window -> Security Assist - Show Region).
after adding the welcome message and links, select them and add the show region behavior using the "Logged Into <Your User table>" Rule (Where <Your User table> is the name of your user table).
to hide the form, select it, then apply the show region behavior using the "Not Logged into <Your User table>" rule.
toms016390756
