Adding a calculation to add extra cost to total
Thread begun 4/06/2012 8:22 pm by phil107723 | Last modified 4/10/2012 1:19 pm by phil107723 | 2649 views | 4 replies |
phil107723
Hi
My product is $200 but a larger size is $50 more. I edited the TotalPrice calculation like this [price]+[option]*[quantity] and this works perfectly up to a point. If a customer wants to buy a second one of the same item it only adds the extra $50 not the cost of the item ($200).
I am giving the option as <input type="radio" name="eCart1_1_FourInchOption_Add" value="50" />.
Any advice would be greatly appreciated.
Phil
the calculation should be:
([price]+[option])*[quantity]
the grouping parentheses are important.
phil107723
Hi Jason
Didn't work after adding the option for the first product(so plus $50) when adding the second item of the same product to the cart it deducted the $50 from the first as well.
I tried this idea you talk about here:
showthread.php?t=25444 but couldn't get it to work either . My options are 4 inch extra $50 or 7 inch no additional charge.
Thanks for your help
In the cart object, is the Size column set to be unique?
this will treat different size products as separate line items to only apply the additional option price to the larger one.
phil107723
Hi Jason
Sorry I redid my initial work today and it worked perfectly. I think after trying different things the other day it all got a bit confused.
As always thanks for your help and patience.
Phil
