Search question - comma separated words?
Thread begun 4/06/2012 9:23 am by iainmacdonald331081 | Last modified 4/11/2012 11:06 am by iainmacdonald331081 | 4910 views | 9 replies |
iainmacdonald331081
I've added a search form to a site here:
search/
I just wanted to check if its possible to search for any words in a search string?
For example, there's a school called 'Driving with Debbie', which is returned correctly if you search for 'Driving with Debbie'.
But should it be possible to find her using just the words 'driving' and 'debbie'? It doesn't currently, at least not with 'driving, debbie'. I couldn't remember if it should be possible, and I've missed something somewhere.
Thanks.
depends on how you configured the search criteria in the data assist wizard.
the criteria for a column can be configured using the "=", "begins with", "includes", or "ends with" comparison.
if you set the comparison to "=", it will only find the school if you enter the full name.
It also depends on the filter type you use.
it sounds to me like you have the criteria set to use the "=" comparison and the value filter type. this will convert the search string:
'driving, debbie'
WHERE school = 'driving, debbie'
if you select the keyword filter type, you can set an AND separator and an OR separator.
from your description of how you want the search to work, you should be using the "Includes" comparison, the keyword filter type and you should set the OR separator to ", " (thats a comma followed by a space). this will convert the search string:
'driving, debbie'
WHERE school LIKE '%driving%' OR school LIKE '%debbie%'
to give the desired results.
iainmacdonald331081
Thanks Jason.
I've attached a screen shot showing a couple of screens from the Server Behaviour Configuration. What do I need to change exactly? In the right hand image, I found the Keyword filter OK - changing type from Edit to Keyword?
But I wasn't sure about the separator - I tried changing the OR in the OR box to a comma, but that started returning all schools regardless of what I entered.
I'm sure this is simple, but if you could look at the screenshot and let k=me know exactly what needs to go where that would be great.
yes, change the type from edit to keyword
for the OR separator, use a comma followed by a space.
iainmacdonald331081
I'm not getting this Jason - I've changed it to Keyword, and changed the OR to a , but now when I search using the School field, its returning every record for any search.
Just to let you know I spotted where it was going wrong - when I changed the search criteria, the //comparison list additions lines of code were using $_POST instead of $_GET - I changed those and it was all OK.
iainmacdonald331081
Can you do me a quick favour though - can you try a few searches for towns from the home page?
As far as I can tell, its all OK, but my client is saying he sometimes gets random, incorrect results. He has most recently said its when he just hits rerun, rather than the search button, but I wouldn't have thought that should make any difference.
Thanks.
this is an issue with IE and image input elements when used as the trigger.
an image element type doers not send a value when submitted, it send x and y coordinates of where the mouse clicked it.
using the enter key bypasses this so that the x and y coordinates are empty.
to work around this, add a hidden form element named "Search_x" to the search form and give it any value.
iainmacdonald331081
Thanks Jason - I added that here :
www.learners-guide.co.uk
Apparently it's OK when the search button is hit, but not when you hit enter.
Can you have a look and check I've made the correct change?
Thanks.
the hidden element does not have a value, you need to give the element a value.
iainmacdonald331081
Thanks Jason - that's all fine now.
I'd used CSS on the contact form:
.searchbutton {
background-color:#FFF;
background-image:url(../images/search2.jpg);
background-repeat:no-repeat;
width:85px;
height:24px;
border:0px;
.searchbutton:hover {
background-image:url(../images/search1.jpg);
But the search didn't like that, so had gone back to the image type.
