storing product options in an order history table
Thread begun 4/04/2012 11:46 pm by Christopher West | Last modified 4/05/2012 9:30 am by Jason Byrnes | 1576 views | 3 replies |
Hi I have a range of product options (due to complexity of them, I had to create them as an array) (the product options are made up as a series of text fields, checkboxes and select lists).
How would I go about storing these in an order history table? I have read a little on the php command "serialize" would it be best to use this method to pass the array into a database?
since there are many different product options relating to a single product I was assuming that I would need 3 tables:
1. order summary
2. orders
3. orderProductOptions
then then "orderProductOptions would have a field that stores the ID from order summary table. Would that make sense?
currently on my cart.php I am displaying the options by this code:
$options = $DinkyCart->DisplayInfo("Options");
$optionArray = explode("<br>",$options);
$optionInfo = array();
for ($x=0; $x<sizeof($optionArray)-1; $x++) {
$optionInfo[] = explode("**",$optionArray[$x]);
<tr>
<td valign="top"><p><strong>Options</strong></p>
<p>
for ($y=0; $y<sizeof($optionInfo); $y++) {
<?php echo($optionInfo[$y][0]); ?>
<br>
</p>
td>
<td align="right" valign="top">
£<?php echo(number_format($optionInfo[$y][1],2)); ?>
<br>
</p></td></tr>
I think you are overcomplicating it.
when eCart stores the order information, it uses an orders table for storing the order summary and an orderdetails table for storing a record for each product in the order using the eCart Store Order Details behavior.
the options are store in the cart options column separated by a <br> tag.
In the eCart Store Order Details behavior, you just need to bind the options column of the order details table to the options column of the cart
ok I need to try this, but before I do, so am I right in thinking that if a product on the cart has many different types of product options (these have different prices as well) then all that will be automatically stored in the options column of the ecart.
I just cannot visualise it at the moment (so obviously I need to try that) before posting I guess. its just that the options I had created from a premier ticket with Ray because the product options arnt like the product options on your website tutorial PDFs. So I needed a hand-coded approach to the ecart. So Im just wondering is the same method your stating will also work with my product options approach.
yes, all of the options for the product are stored in the options column of the cart separated by a <br> tag;
option1<br>option2<br>options3<br>
all you need to do is bind the options column of the order detail table to the options column of the cart.
