Order Number is too long
Thread begun 4/03/2012 6:45 am by Magega49 | Last modified 8/29/2012 7:57 am by Jason Byrnes | 12352 views | 47 replies |
Magega49
Hello,
Can you please help me on how can I change my order number to start withjust 6 to 8 numbers?????? For esample 000012 The way its now it has like 20 numbers and some letters...
Please.
it sounds you are using the Session ID as the order number.
on the confirm page, there is a Store order Summary behavior, this stores the id of the record created for the order in a session variable, you can use this session variables value as the order ID if you like. you should be able to access the session on the bindings panel.
Magega49
Order ID
Hello,
I try to used the ID us Order number but when I do that I get the Item name that I created when i created my add to cart botton.......
I really need a order ID that start with 0050 and next customer will automatic get 0051, next 0052 and so, on.
Also if you can just tell me how to set the order number to begin with 0050??
Can you please try to help me on this one more time....
jspoerer286380
I´m also having the same problem Jason....
Magega49
Try this page
Hello, Jason
I want to show you this page before we go to create a new ticket to see if maybe you can see the issue quicker here...
ecart_checkout_success.php This is a direct link that you can see where my order number is showing to long I think that is scripted this is why is showing so, long.
See att: to see my page.
this page is set to use the session id for the order number.
Order number: <?php echo session_id() ?>
on the confirm page, look at the store ordersummary behavior in the store as section, this sets a session variable to use for the order ID, use the binding for that session variable on the success page instead of the session ID.
Magega49
Jason,
I used the one that says ID but I try to different transaction to see and is using the same ID for all transaction...
How do I set up to use different ID every time that user place an order...????
add the following code to the checkout success page after the closing /html> tag:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
session_regenerate_id();
