Server Validation - Repopulating Checkbox Array
Thread begun 4/03/2012 3:42 am by Ian S | Last modified 4/04/2012 6:23 am by Jason Byrnes | 4697 views | 3 replies |
Ian S
Hi WA,
I have a form with a checkbox array. Nothing fancy, just some checkboxes named Checkbox[]
The form has Server Side validation on it.
How easy (or not) is it to get these repopulated should the validation of the form fail?
Is it a quick task or slightly more involved?
Cheers
Ian
it's not a quick task, it is definitely more involved and requires hand coding.
first, a multiple checkbox like this will pass the selected values using an array. to validate the checkboxes, the array needs to be converted to a comma separated string.
add the following code at line 1 to do that:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
when validation fails, the validated entries code for the checkbox (yours may look different):
<?php echo(ValidatedField("pagename","Checkbox")) ?>
will give us a comma separated list of the checked items, we need to convert that back to an array by adding the following code just before the form tag
<?php $selected = explode(", ", ValidatedField("untitled4","Checkbox")); ?>
then in each checkbox, we can use the in_array function to see if that checkbox value is in the array, for example:
<input type="checkbox" name="Checkbox[]" value="1" <?php if(in_array("1", $selected)) echo("checked=\"checked\""); ?> id="CheckboxGroup1_0" />
      Checkbox</label>
    <br />
    <label>
      <input type="checkbox" name="Checkbox[]" value="2" <?php if(in_array("2", $selected)) echo("checked=\"checked\""); ?> id="CheckboxGroup1_1" />
      Checkbox</label>
    <br />
    <label>
      <input type="checkbox" name="Checkbox[]" value="3" <?php if(in_array("3", $selected)) echo("checked=\"checked\""); ?> id="CheckboxGroup1_2" />
Ian S
This post has been deleted.
Ian S
Hi Jason,
I just wanted to let you know that thanks to your clear explanation and helpful code snippets that I was able to resolve my issue very quickly indeed!
Thanks as always!
Cheers
Ian
glad to hear it is working.
