Strange Download behavior?
Thread begun 4/01/2012 2:44 pm by Brad Lawryk | Last modified 7/10/2012 9:06 pm by Brad Lawryk | 4983 views | 6 replies |
Brad Lawryk
Hi guys,
For some reason the file download will not download word documents?
It downloads but can't open the file it needs to be converted. See attached...
Brad Lawryk
Has to be something with the download extension because I can upload a file and then download it through FTP no problem, but if I download it with the download button it doesn't open.
I'm not able to reproduce the problem, can you send a screen shot showing the download behavior settings you have used? if necessary, i will start an incident so we can investigate the problem further.
Brad Lawryk
Yeah I still can't get this to work for the life of me.
Here is a screenshot of my settings.
Brad Lawryk
Ok, I can confirm it only happens when page is included using Framework.
The page by itself downloads the file fine. If the page is included it downloads but word docs are corrupted.
Brad Lawryk
Had a good long Connect session with Ray today. I think we may have found a work around at least in testing. I'll give it a go on live use in the morning and get back to you guys.
Thanks Ray.
Brad
info4753
Got the same problem here.
Direct download of word documents works, but not via download script.
Thanks for any help
info4753
There where some empty lines in the connection php file after the closing ... &>
That causes \r\n at the beginning of the worddokument.
