Validation messages on right column not display
Thread begun 4/01/2012 12:07 am by dvan_zelst | Last modified 4/02/2012 11:57 am by Jason Byrnes | 1281 views | 2 replies |
dvan_zelst
Dear Support Team,
I have some question about the Form Builder Tool.
1. When i create a 2 column form all my validation messages on the left column show up under the input field, however on the right column they do not show up. Nor to the right of the input field nor under the input field. I do see part of the surrounding red outline for the message but no message.
2. When i design the form within the Form extension and want to style the Menu form field type - initial state border or background color etc. Once i change the initial state to another state and back, then my previous setting are reset back to nothing.
3. How can i style the font size and family of the File type input field? I want the font family and fontsize to be the same as all other input fields which are able to style within in the extension but the file type not.
At last i hope you will be able to add CSS3 support (rounded corners, gradients etc.) to all your extensions in the near future.
Thanks for your support.
Dave
dvan_zelst
Somehow issue one has solved itself and i don't know why but the validation messages on the right column side show up correctly now.
One other thing is that in the right column i have a file input field but only in IE9 it does not show on the right side but on the left side. Is it because IE9 does not style file fields correctly? In firefox and Chrome it shows correctly.
Also i would like to know how to put a mask in the URL type text input field like http:// and still accept blanc input. When i choose URL type validation then i cannot put this mask because leaving only the protocol will validate it as not being blanc, putting no validation will force anything being able to insert.
Last it would be good to be able to set the tab index from within the extension as now that i have a 2 column form i have to go through the code to re-organize my tab indexes.
