MySQL error#: 1045
Thread begun 3/31/2012 5:33 pm by elevy388997 | Last modified 10/13/2014 9:03 am by Jason Byrnes | 6009 views | 6 replies |
elevy388997Beta Tester
MySQL error#: 1045
I am trying to setup a dynamic MySQL database connection and I am getting this error when I click "Test":
"MySQL error#: 1045
Access denied for user 'cts_brett'@'localhost' (using password:YES)"
I checked the username and password for the MySQL database and I am entering it in correctly. The password has these two characters in it ] ( is that a problem?
Any help will be great. Thanks
Well it seems that my hosting company had to add a firewall exception in order for it to work, then I had to add my STATIC ip to the remote MySQL Connections list. All is working now.
Glad to hear you have it working.
anonymous
now i have the same problem, what exactly should i do to get it work
The 1045 error means that the server is not accepting the username and password combination you are using in the connection. you should contact the host for help in setting up the database connection, double check that the hostname, username, password and database name you are entering is correct.
anonymous
yes, but the user name and password and database name is correct , i followed the instructions from adobe : http://www.adobe.com/devnet/dreamweaver/articles/first_dynamic_site_pt2.html
in the site settings, how have you configured the testing server?
Is it connecting to a local server? or a remote server?
If connecting to the remote server, the database connections details needs to use the remote settings, if the testing server is connecting to local server, the database connection needs to use the local connection information.
