Name field added price
Thread began 3/30/2012 11:33 am by sjuno299871 | Last modified 3/30/2012 4:32 pm by sjuno299871 | 1325 views | 4 replies |
sjuno299871
Jason last post worked great could I get the coding on my text field for this situation.
I have on the product page a text field that they can enter in a name to be added to the product. In the calulations field what do i do for this -
If field blank no price increase. If field has text in it add $3.25 to price of product.
Thank you for again previous post added it to my notes so next time I can just review them.
in the cart object, create a new calculation called realPrice, my example of the code to use for the realPrice calculation is based on a column named "Name" (including case), if your is different, you'll need to adjust it accordingly:
realPrice:
abs([Name] != '')?[Price] + 3.25:[Price]
then modify the Total Price calculation from:
[Price] * [Quantity]
(abs([Name] != '')?[Price] + 3.25:[Price]) * [Quantity]
int he cart display, you will need to change that code that displays the price to use the new realPrice calculation instead. this will also need to be changed in the code that sends the order to the gateway and in the store order details behavior.
sjuno299871
just checking on syntax
Already using for sizing
truePrice -[Price] + [sizePriceInc]
incrementSize - (abs([size] == '2XL')?[sizePriceInc] =1:'')+(abs([size] == '3XL')?[sizePriceInc] = 2:'')+(abs([size] == '4XL')?[sizePriceInc] = 3:'')
TotalPrice -([Price] + [sizePriceInc]) * [Quantity]
How would I add the rest of needed pricing so I do not goof
Thanks again
change:
truePrice -(abs([Name] != '')?[Price] + 3.25:[Price]) + [sizePriceInc]
and Total price:
TotalPrice -((abs([Name] != '')?[Price] + 3.25:[Price]) + [sizePriceInc]) * [Quantity]
sjuno299871
Thank you
Great help ;-)
