login cms error
Thread begun 3/29/2012 10:58 am by axisbold2k2 | Last modified 4/24/2012 1:29 pm by Jason Byrnes | 4499 views | 7 replies |
axisbold2k2
login cms error
Found the login but now I'm getting this error:
Fatal error: Cannot redeclare wa_authenticateuser() (previously declared in /hermes/waloraweb063/b468/pow.bqire5hz/htdocs/bostonkappa/webassist/security_assist/helper_php.php:28) in /hermes/waloraweb063/b468/pow.bqire5hz/htdocs/bostonkappa/WA_SecurityAssist/Helper_PHP.php on line 46
comment out the require once line for the webassist/security_assist/helper_php.php file at line 28.
axisbold2k2
commenting out not working
This is from line 1 - 55. I tried commenting out different lines as you directed but that didn't seem to work. What is causing this error?
- File Name:
- Helper.php
- This file contains proprietary and confidential information from WebAssist.com
- corporation. Any unauthorized reuse, reproduction, or modification without
- the prior written consent of WebAssist.com is strictly prohibited.
- Copyright 2011 WebAssist.com Corporation. All rights reserved.
@session_start();
$securityassist_helper_Include_Start_Dir = getcwd();
chdir(dirname(__FILE__));
require_once("helpergroupsrulesphp.php");
if (file_exists("mail_php.php")) require_once("mail_php.php");
if (file_exists("wa_cryptencryption.php")) require_once("wa_cryptencryption.php");
if (file_exists("wa_hashencryption.php")) require_once("wa_hashencryption.php");
if (file_exists("wa_md5encryption.php")) require_once("wa_md5encryption.php");
if (file_exists("wa_rijndaelencryption.php")) require_once("wa_rijndaelencryption.php");
if (file_exists("wa_sha1encryption.php")) require_once("wa_sha1encryption.php");
chdir($securityassist_helper_Include_Start_Dir);
$WA_Auth_Separator = "|ยค|";
$_SESSION["WAENCRYPTEDRETURNUSED"] = false;
$_SESSION["WAENCRYPTEDRETURNSUCCESS"] = false;
function WA_AuthenticateUser($WA_Auth_Parameter){
$UserAuthenticated = false;
mysql_select_db($WA_Auth_Parameter["database"], $WA_Auth_Parameter["connection"]);
$WA_Auth_loginSQL = "SELECT `".implode('`,`', $WA_Auth_Parameter["sessionColumns"])."` FROM `".$WA_Auth_Parameter["tableName"]."` WHERE ";
for($idx=0;$idx<count($WA_Auth_Parameter["columns"]);$idx++){
$WA_Auth_loginSQL .= sprintf((($idx!=0)?" AND ":" ")."`%s`=%s ", $WA_Auth_Parameter["columns"][$idx], WA_GetSQLValueString($WA_Auth_Parameter["columnValues"][$idx], $WA_Auth_Parameter["columnTypes"][$idx]));
$WA_Auth_RS = mysql_query($WA_Auth_loginSQL, $WA_Auth_Parameter["connection"]) or die(mysql_error());
$WA_Auth_Rows = mysql_num_rows($WA_Auth_RS);
if($WA_Auth_Rows){
$UserAuthenticated = true;
$idx = 0;
foreach ($WA_Auth_Parameter["sessionNames"] as $sessionName){
$_SESSION[$sessionName] = mysql_result($WA_Auth_RS,0,$WA_Auth_Parameter["sessionColumns"][$idx]);
$idx++;
if (isset($_GET['accesscheck'])) {
$WA_Auth_Parameter["successRedirect"] = urldecode($_GET['accesscheck']);
if($WA_Auth_Parameter["successRedirect"]!=""){
$WA_Auth_Parameter["successRedirect"] = WA_Auth_BuildRedirectURL($WA_Auth_Parameter["successRedirect"], $WA_Auth_Parameter["keepQueryString"], FALSE);
header("Location: ".$WA_Auth_Parameter["successRedirect"]);
exit();
it not the webassist/security_assist/helper_php.php file that needs to be edited, it is the login.php file that needs to be changed.
axisbold2k2
Help editing Login.php
Here is the error message
admin_cms/
What do I comment out in login.php(below)....commented out what you suggested and that didn't work.
Login.php
@session_start();
<?php require_once('Connections/bostoncms.php'); ?>
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
if ((isset($_POST["LogIn_submit"])&&(!isset($_POST["Log_In_group_Remember_my_information"])) && $_POST["LogIn_submit"] != "")) {
setcookie("RememberMePWD", "", time()+(60*60*24*30), "/", "", 0);
setcookie("RememberMeUN", "", time()+(60*60*24*30), "/", "", 0);
if ((isset($_POST["LogIn_submit"])&&(isset($_POST["Log_In_group_Remember_my_information"])) && $_POST["Log_In_group_Remember_my_information"] != "")) {
setcookie("RememberMePWD", "".((isset($_POST["Log_In_group_Password"]))?$_POST["Log_In_group_Password"]:"") ."", time()+(60*60*24*30), "/", "", 0);
setcookie("RememberMeUN", "".((isset($_POST["Log_In_group_Email"]))?$_POST["Log_In_group_Email"]:"") ."", time()+(60*60*24*30), "/", "", 0);
if ((isset($_POST["LogIn_submit"])&&(!isset($_POST["Log_In_group_Log_me_in_automatically"])) && $_POST["LogIn_submit"] != "")) {
setcookie("AutoLoginPWD", "", time()+(60*60*24*30), "/", "", 0);
setcookie("AutoLoginUN", "", time()+(60*60*24*30), "/", "", 0);
if ((isset($_POST["LogIn_submit"])&&(isset($_POST["Log_In_group_Log_me_in_automatically"])) && $_POST["Log_In_group_Log_me_in_automatically"] != "")) {
setcookie("AutoLoginPWD", "".((isset($_POST["Log_In_group_Password"]))?$_POST["Log_In_group_Password"]:"") ."", time()+(60*60*24*30), "/", "", 0);
setcookie("AutoLoginUN", "".((isset($_POST["Log_In_group_Email"]))?$_POST["Log_In_group_Email"]:"") ."", time()+(60*60*24*30), "/", "", 0);
axisbold2k2
Ticket Status?
any update
I have been waiting for you to update the ticket with the requested contact information.
Please update the ticket with the requested contact information so we can look into the problem with you.
