The line item [item number] is invalid.
Thread begun 3/27/2012 7:47 pm by john42771 | Last modified 3/28/2012 8:23 am by Jason Byrnes | 2209 views | 3 replies |
john42771
Almost operational - hope someone can help soon.
Where do I go to address this issue revealed on the checkout failure page?
The Auth.Net debugging code revealed the following:
Your transaction could not be completed.
Our payment gateway, Authorize.net has declined this transaction for the reasons listed below.
Response Code: 3
Reason Code & Text: 270 : Line item 1 is invalid.
270 -The line item [item number] is invalid.
A value submitted in x_line_item for the item referenced is invalid.
Transaction ID: 0
this error usually happens if one of the fields passed to Authorize.net in the checkout contains special characters like "<", ">", "&", "!". make sure the item names and descriptions going into the cart do not contain any characters that are not alpha-numeric.
john42771
Thank you - that's it.
Thank you - that's it -working now.
you're welcome.
