error when adding page access to a New page
Thread began 3/27/2012 5:27 pm by turk361661 | Last modified 4/02/2012 10:04 am by Jason Byrnes | 781 views | 3 replies |
turk361661
Originally I used Security Assist wizard to create a small back-end administrative area where my clients can login and manage some pages of their site. Only they have access to these pages via the login.
Recently I created a new page, which I added to the same directory/folder as my other admin pages.
How do I make this new page only accessible after logging in?
I tried using the Modify > Security Assist > Pages Manager to grant access to this newly created page, but I get an Error (See Screen Shot attached).
Can you please advise on the best way to protect this new page with the same login/password I used on my other pages?
that error means that the page you are trying to protect is open in dreamweaver, you will need to close that page before using the page access manager wizard to protect it.
turk361661
Hi Jason,
I applied the page access to my new page. It is working.
However, now I'm having a different problem. After filling out the form, this page should be redirected to download.php (see screen shot)
Instead it stays on the same page. I'm overlooking something. Can you please take a look at my files attached.
Thanks for your help,
Danielle
AvailUpdate_0402_2_php.txt
most likely it is a probelm with PHP errors, but error reporting is turned off.
at lines 46 - 48:
the space between php code blocks is enough to break the redirect.
delete that blank line at line 47.
if you still have problems, add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
and see this post for details on the headers already sent error which occurs as a result of blank space between php tags:
showthread.php?t=19285
