Missing Email for Submit
Thread begun 3/27/2012 3:19 pm by tom92909 | Last modified 3/28/2012 7:35 am by Jason Byrnes | 4809 views | 12 replies |
tom92909Beta Tester
Greetings Folks. I started this project yesterday morning. I installed CSS Form Builder v2.01 today after removing the individual products that are now components of Form Builder. I spent several hours creating a custom form. The form page itself looks great, I then wanted to utilize Universial Email (which is now part of Form Builder), so I setup the messaging portion as directed. I setup the mail server as I have in the past using UE4, I added a physical file attachement, input the From and To, and the Subject. As for the message body, I haven't really done much to customize that at this point so I just left it using the Default style.
The issue I'm having is that I click submit, and I get nothing. The page redirect or goto page that is defined in UE doesn't occur either.
I'm at a loss.
ok, that means that email is not being triggered to send, perhaps because of a validation failure. Please send a copy of the page so i can look at the code to have an idea why.
tom92909Beta Tester
See attached...
first, make sure no php error are occurring, add the following code at line 1 to turn error reporting on:
error_reporting
(A_LL);
next, make sure no validation errors are occurring, change the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"registrationform");
    die($WAFV_Errors."<br><br><br><br>".var_dump($_POST)."<br><br><br><br>'.var_dump($_SESSION));
post back the results of trying to submit the form with those changes.
tom92909Beta Tester
I found the line...
I made the edit to the line and got a syntax issue in Dreamweavers CS 5.5
See attached screenshot.
sorry, had a single quote where a double quote was needed, the correct code is:
    die($WAFV_Errors."<br><br><br><br>".var_dump($_POST)."<br><br><br><br>".var_dump($_SESSION));
tom92909Beta Tester
The output for the page submit is as follows;
array(19) { ["Summer1"]=> string(1) "1" ["Summer2"]=> string(1) "1" ["Dance"]=> string(1) "1" ["First_Name"]=> string(3) "Tom" ["Last_Name"]=> string(6) "Tester" ["age"]=> string(2) "40" ["contact_phone"]=> string(14) "(123) 123-1234" ["emailaddress"]=> string(17) "tom92909@webassist.com" ["Address_1"]=> string(14) "123 Elm Street" ["City"]=> string(8) "Anywhere" ["State"]=> string(2) "AL" ["Zip"]=> string(5) "12345" ["parent_name"]=> string(3) "Mom" ["daytime_phone"]=> string(14) "(555) 123-1234" ["emergency"]=> string(14) "(555) 222-3333" ["schools"]=> string(4) "None" ["years"]=> string(1) "1" ["Registration_group_Security_code"]=> string(5) "EWdTk" ["RichRegistration_submit"]=> string(25) "Send Student Registration" } array(2) { ["captcha_Security_Code_1"]=> &string(5) "EWdTk" ["WAVT_registrationform_Errors"]=> &string(0) "" } ,12
OK, that means that the captcha is failing validation.
in the server validation server behaivor, you have the like entry validation for captcha set to compare the "Registration_group_Security_code" form element against the "captcha_Registration_group_Security_code" session variable.
in the image tag that creates the captcha image:
<img id="capt1"  src="webassist/captcha/wavt_captchasecurityimages.php?width=200&height=50&field=Security_Code_1&bgcolor=FFFFFF&transparent=0&bgimage=&gridfreq=20&gridcolor=000000&gridorder=behind&noisefreq=17&noisecolor=000000&noiseorder=behind&characters=5&charheight=&font=fonts/MOM_T___.TTF&textcolor=000000" alt="security code" width="200" height="50" />
one of the variables that is passed is name d"field:
the captcha session name is created as "captcha_<field value>" so the session variable you should be using is named "captcha_Security_Code_1".
you will need to edit the like entry server validation to compare the "Registration_group_Security_code" form element against the "captcha_Security_Code_1" session variable
tom92909Beta Tester
Whooo Hooo! Good morning Sir! After a good nights sleep, I found that very thing that the error output was referencing 12, but I had no idea how to fix it...
This is what I'm looking at...
The Form Portion
<div class="fieldGroup"><table><tr><td><img id="capt1" src="webassist/captcha/wavt_captchasecurityimages.php?width=200&height=50&field=Security_Code_1&bgcolor=FFFFFF&transparent=0&bgimage=&gridfreq=20&gridcolor=000000&gridorder=behind&noisefreq=17&noisecolor=000000&noiseorder=behind&characters=5&charheight=&font=fonts/MOM_T___.TTF&textcolor=000000" alt="security code" width="200" height="50" /></td><td><img src="webassist/captcha/images/refresh.png" height="18" onClick="document.getElementById('capt1').src+='&ref=1'"></td></tr></table></div>
The Validation Portion
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Registration_group_Security_code"])?$_POST["Registration_group_Security_code"]:"")) . "",((isset($_SESSION["captcha_Registration_group_Security_code"]))?strtolower($_SESSION["captcha_Registration_group_Security_code"]):"") . "",true,12);
I understand that I need to change the LIKE part, but actually editing the validation is the issue. I don't see how to actually locate the Validation Tool. Before when I used it outside of Form Builder, it wasn't really that difficult, but now that everything is bundled together, I'm not finding the utility within the page properties, I can easily access the progress bar properties and the CSS Form properties (Edit Form, Edit Design, Edit Contents).
Do I just hand code the change? Replacing
with
strtolower($_SESSION["captcha_Security_Code_1"]):"")
by hand?
As always, thank you for your patience with me.
tom92909Beta Tester
I hand coded the change and it works perfectly!
As always I truly appreciate you and the whole WebAssist team for providing the best Dreamweaver Extensions available in the World!
