conditional vars in framework
Thread begun 3/27/2012 10:47 am by Steve | Last modified 3/27/2012 11:11 am by Steve | 1352 views | 2 replies |
Steve
Hello,
I have a site that uses the framework for templating.
Within the primary dw template I want to add a condition where IF a variable is present (isset) then echo the value.
Basically it is code that will only fire when a page has a particular recordset (rs_invType) and value (typeName).
Problem: Value is not found when placed in the template.
Code:
<?php if (isset($row_rs_invType['typeName'])) { ?>
  <div class="redBorder" style="width:240px; height: 30px; margin-left:300px; margin-top:40px;">
here : <?php echo $row_rs_invType['typeName']; ?>
  <!-- inventory title -->
  </div>
  else {
  <!-- not found -->
  <?php ?>
While this code works perfectly in the page that actually creates the recordset it fails when set to the template.
Is the problem that the template is server side processed fully before the page where the template is applied?
Do they not have all the pre HTML server side code processed before moving to the conditional statements in either document?
you will need to add the rs_invType recordset to the template.
Steve
Thanks for the reply Jason.
I was hoping to streamline by sharing a recordset. And only show a value when this recordset was present as other pages that share this template will not have the value available to display.
Not a problem, I'll have to add a recordset that only gets called IF the page has a specific value such as the ID from a $_GET...
