How to add a Promo Code
Thread begun 3/26/2012 11:40 am by cicyou421883 | Last modified 4/27/2012 2:57 pm by Jason Byrnes | 6727 views | 13 replies |
cicyou421883
I have Super Suite and need to add a promo code for free shipping. We currently have flat rate shipping set-up at a rate of $5.99. When a customer finds this special promo code, this flat rate of $5.99 would be deducted. Please advise as to how to set-up this promo code. Could not find tutorials.
in the archived documentation section of the eCart support page:
ecart/
there is a tutorial titled "Creating a Coupon system for your eCart store", it was written for an earlier version of eCart, but the steps are the same in the current version.
cicyou421883
Tried the PDF Tutorial
Hey Jason, I have tried the PDF tutorial for this PromoCode several times since your post and cannot get the cart to respond. Everything seems correct, but nothing happens when I put to server.
Cart Page: Using PromoCode, I listed last vale at minus 5.99 discount for free shipping.
cart.php
Thank you. Cathy
send a copy of the cart.php page and the eCart object file from the WA_eCart folder please.
cicyou421883
Attachments for your review
Jason, cart.php PDF attached. When looking for the object file from the WA_eCart, In dreamweaver I created the e-cart object but cannot find the word object listed in the WA_ecart folder. I did see the word that I entered in the Webassist object panel in the californianatural_PHP.php file so I am sending that PDF.
If you need something else, let me know. Thanx, Cathy
Ok, so i see from the cart object file that you have set up the discount to apply if the promo code that is entered is:
WebAssist
testing your site and using the code "WebAssist" seams to work as intended, what promo cade are you testing with?
Note: PHP is case sensitive. "WebAssist" and "webassist" are not the same, make sure to use the correct case when entering the promo code.
cicyou421883
Promo Code Resolved
Hey Jason, Thank you so much for telling me that the coupon code was WebAssist. I followed the tutorial and thought PromoCode was the coupon code. The tutorial did not show me this as clearly as you have. I have changed WebAssist to what I want to call the coupon. Again thank you for your quick witted response. Best Regards, Cathy
you're welcome.
cicyou421883
Promo Code not working for certain items
Hey Jason, So I found a bug. Current name of promo code is: biocell
The flat rate discount remains at 5.99 so there is free shipping.
Items on site that are less than 5.99 (IE: hair and nails are price at 4.99) when purchased with a quantity of 1, the promocode "biocell" eliminates the shipping set at flat rate of $5.99 and just applies the promo code flat rate discount. Therefore the total in cart is -$1.00 so we owe them $1.00.
I have tried to add session variables to create a subtotal of cart must be >.01 and many other like attempts, but Nothing appears correctly.
I have kept my current attachments the same as your last review.
Thank you for your help. I have tried for 2 hours to find the correct session variable with no luck.
Best Regards, Cathy
you need to add a trigger to the discount rule so that it will only apply if the cart subtotal is > 5.99
in the discount rule add another trigger:
AND
Taxable total for the cart is > 5.99
