Blank Page
Thread begun 3/25/2012 8:54 pm by jim286478 | Last modified 3/27/2012 7:34 am by Jason Byrnes | 2554 views | 6 replies |
jim286478
Blank Page
I have created a page with an html form on it. Using Form Tool Kit 1.0 I have inserted a captcha and applied server validation to the captcha and a few of the other fields. I then used UE4 to have the form emailed to me. I uploaded the page and all dependent files to my server and when I view it in a browser the page is blank, the error message I get from the browser is "internal server error". However, the page shows up fine if I delete the php scripts WA installs. In other words the html page and form seem to be OK.
I have tried but can not find the problem. I do appreciate some help on this.
I have attached a zip file of the page.
try adding the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
jim286478
Blank Page
Jason here is the error messages:
Warning: require_once(/webassist/form_validations/wavt_scripts_php.php) [function.require-once]: failed to open stream: No such file or directory in /home3/igwebsco/public_html/submitlink.php on line 4
Fatal error: require_once() [function.require]: Failed opening required '/webassist/form_validations/wavt_scripts_php.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home3/igwebsco/public_html/submitlink.php on line 4
This means it can't find the file but its uploaded and I check on the server, its correctly positioned in the right folder and it is there! This is weird!
it's probably the leading slash in the require once location.
the require once location expects a document relative link rather than a site relative link
jim286478
I have tried it without the leading slash but nothing. I even change the file location to the main folder and nothing.
Tried this:
<?php require_once("/webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("/webassist/form_validations/wavt_validatedform_php.php"); ?>
and this:
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
and this:
<?php require_once("wavt_scripts_php.php"); ?>
<?php require_once("wavt_validatedform_php.php"); ?>
and still it can't find it. What am I doing wrong please?
jim286478
OK I got it. Changed it to document root and it working now but the email won't send!
in the email behavior, you have is set to redirect to the thankyou.html page. Is it redirecting to that page or just reloading?
the answer to this question will determine where to look for the problem.
if it is just reloading it means there is a problem with the validations on the page.
I see that you have3 different validation server behaviors, you should only have one that is used to perform all of the validations.
If it is directing to the thankyou.html page, it means the email is being sent to the SMTP server, but the SMTP server is refusing to relay the message. you will need to double check the email server settings, the from address and the to address to make sure they are correct for your server.
