DataAssist Wizard Error when try to connect
Thread begun 3/23/2012 6:13 am by diazc1369085 | Last modified 4/23/2012 6:28 am by Jason Byrnes | 3015 views | 5 replies |
diazc1369085
I am new using the DataAssist and when I try to use the DataAssist Wizard to mysql database it does not find the file and I do keep getting an error message, please see files attached. Any help will be appreciated and thank you in advance.
Diaz
the error means that the Dreamweaver Site Definition is not set up properly.
In the Site Definition, double check the settings for connecting to the Testing Server, pay careful attention to the settings for the Host Directory and the URL Prefix, the error you are getting means that one or both of those settings is incorrect.
The URL PRefix should be the site address for your site. The Host Directory should point to the web root folder on your server.
If you copy the address used for the URL Prefix setting and paste it into the address bar of your browser, it should load your testing server site.
In the testing server Tab are you using an FTP Connection?
if you open the file panel (Window -> Files) and change the file view from local to testing what do you see? can you send a screen shot of the files panel list in a zip archive.
diazc1369085
Ji Jason,
Here is the screen shot of the site panel. When I test the page it comes balnk. Any idea what I did wrong.
the link of the page: index_info_Search.php
Thank you in advance.
Diaz
a blank page means that a php error is occurring.
add the following code at line 1 to turn on error reporting, once we know the error, we will be able to tell more about what is causing it:
error_reporting
(E_ALL);
diazc1369085
Hi Jason,
I did add the code on line 1 but still showing as a blank page.
Diaz
