Order does no store in table
Thread begun 3/23/2012 5:24 am by pau376010 | Last modified 3/30/2012 12:31 pm by Jason Byrnes | 2974 views | 5 replies |
pau376010
I am testing Ecart5 locally and find that new order does not add to orders table but substitutes the last one.
I can prevent this by either reiniciating the browser or doing logout/login. In this case, stores correctly the new order in both orders and orderdetails tables.
If I use in in production, in the case a customer made 2 or more orders, just the last one would remain. How could I avoid the problem?
I have even tried to manually change PHPSESSID by means of script
session_regenerate_id();
but it doesn't work and old orders still disappears.
Thnks for your help.
Pau Alvarez
add the following code to the checkout success page just after the closing </html> trag:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
@session_destroy();
pau376010
Orders do not store
When using your code, it simply disconnects the user. I would require a system that gives a new "order_id" without need of having to login again.
For time being, I have made a system that disconnects and logins the visitor in an automatic way, so that visitor will not know it, except for the fact that he sees 2 transitory pages running in the screen. It is, however, not quite an elegant way.
Perhaps I missed that I had to customize the red letters to something different?
the user login is maintained through session variables.
to maintain the users as being logged in, you will need to know the names of the sessions that are crteated at login type, save them to application variables, then reset them after the session is restarted.
for example, if the login script creates sessions name "UserID" and "UserName", you can modify the session destroy code to save them and reset them like this:
@session_start();
//Save login sessions
if(isset($_SESSION['UserID'])) $UserID = $_SESSION['UserID'];
if(isset(
$_SESSION['UserName'])) $UserName = $_SESSION['UserName'];
@session_destroy();
//Rest login sessions:
if(isset($UserID)) $_SESSION['UserID'] = $UserID;
f(isset($UserID)) $_SESSION['UserName'] = $UserName;
pau376010
Orders do not store
Now it works. Thank you for your indications.
Anyway, just for you to know, please note that it didn't work until I added
@session_start();
after
@session_regenerate_id();
It was quite hard to discover, as I am not an expert, but the result was worth.
Regards
glad to hear it is working, I've not had to use the session start function after regenerating the ID before, but thanks for posting this, i will keep it in mind for the future.
