Simple form, 1 field, pdf won't upload
Thread begun 3/22/2012 7:00 pm by bjgarner241692 | Last modified 3/26/2012 8:39 am by Jason Byrnes | 4117 views | 3 replies |
bjgarner241692
I don't see why this simple form work?
<?php require_once("../webassist/file_manipulation/helperphp.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../AdvHTML_Upload/pdfs/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct
("WA_UploadResult1");
if((((isset(
$_POST["Upload"]))?$_POST["Upload"]:"") != "")){
WA_DFP_UploadFiles("WA_UploadResult1""newpdf""0""""false"$WA_UploadResult1_Params);
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Untitled Document</title>
</head>
<body>
<form  action="ck-confirm.php" method="post" enctype="multipart/form-data" name="form1" id="form1">
  <label>
    <input type="file" name="newpdf" id="newpdf" />
  </label>
  <label>
    <input type="submit" name="Upload" id="Upload" value="Upload" />
  </label>
</form>
</body>
</html>
probably a dumb question, but i have to make sure:
the forms action is to post to a page named ck-confirm.php, is the name of the page the form is on?
To submit the form, are you clicking the submit button or are you hitting the keyboard enter button?
I ask because you have the trigger set to the submit button pressed, in some browsers (cough, IE, cough), the submit button is not included in the form when there is only one other element.
to help troubleshoot, turn on error reporting by adding the following code at line 1:
error_reporting
(E_ALL);
ini_set('display_errors','on);
also, add the dfp debug info binding to the page. from the bindings panel, expand the WA Uploaded Files Global status and drag the debug info binding, post back the debug info and any errors that occur after trying the upload again.
bjgarner241692
The page this form is on is called ck-listing.php.
It is posting to a different page.
It does post, it just does not upload.
Changed to post to the same page as the form to capture this information.
__
Status object: WA_UploadResult1
statusCode : 1
errorMessage :
clientFileName : blank2.pdf
fileExtension : pdf
serverFileName : blank2.pdf
serverSimpleFileName : blank2
serverDirectory : C:\EDITED\AdvHTML_Upload\pdfs\
contentType : application/pdf
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : 34469
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
fileExtension : pdf
serverDirectory : C:\Inetpub\vhosts\impcoautomotive.com\httpdocs\AdvHTML_Upload\pdfs\
fileSize : 34469
imageWidth : -1
imageHeight : -1
fileWasSkipped :
fileWasRenamed :
statusCode : 1
__
Rule number 1 when working with forms:
All form Processing must occur on the forms action page
if the form is on "ck-listing.php" and the action is set to another page, in this case "ck-confirm.php":
the processing must occur on the ck-confirm.php page.
by changing the post to point to itself, you have set the form to post to the page that has the upload behavior on it, which is why the upload is successful.
if the action points to the ck-confirm.php page, the upload behavior must be on the ck-confirm.php page
