Transferring CMS to Live Server
Thread begun 3/22/2012 10:31 am by Chris Bernard | Last modified 3/29/2012 3:05 pm by Chris Bernard | 3063 views | 4 replies |
Chris Bernard
I have set up Power CMS on my local server to create and setup my clients site I now want to transfer it including the database to GoDaddy. I have already created the database at GoDaddy and have a user name and password there what do I need to do to make the transfer easy.
you will need to export the database from your local MySQL Server, the import it to the MySQL Server on GoDaddy.
I found this page through Google which has instructions for backing up a database and restoring it in PHPMyAdmin:
mysql-database-backup-restore-phpmyadmin.php
you will need to edit the Connections/PowerCMSConnection.php file with the information for connecting to the go daddy database server, then upload the entire site.
Chris Bernard
Connection Still Not Working
For some reason I am not able to connect to the PowerCMS Database I changed the connection info and also backed up the local db and imported it to the godaddy database for Power CMS any suggestions here is the link to the site. www.robertovetlocum.com. Also if I purchase the dynamic connection extension will that help solve this problem moving ahead with new sites.
Chris Bernard
Fixed Issue
I fixed the problem it seemed to be a problem with the db server host name I was able to resolve the problem with go daddy and now everything is working, thanks for your reply.
