PowerStore 4.5 Changing the sub menu width
Thread begun 3/21/2012 8:38 am by admin140217 | Last modified 3/26/2012 1:53 pm by Jason Byrnes | 2937 views | 9 replies |
admin140217
I am trying to change the submenu width to accommodate the longer product categories but can't seem to find where to do this, the menu is too narrow.
Is there a simple way to do it that I'm missing?
change the level 1 submenu to 200px wide by editing the webassist/plugins/main_menu/menu.php file. add the following styles:
ul#cssmw > li > ul.level-1 > li > a {
width:200px;
ul#cssmw > li > ul.level-1 > li > ul.level-2 {
left:60px;
admin140217
looks much better
This worked great Jason, looks a lot better but I need to apply this to the sub menu level 2 (the sub menu off the level 1 sub menu) too, btu I don't see where that is.
Any pointers for that?
add another selector:
ul#cssmw > li > ul.level-1 > li > a li > ul.level-2 {
width:200px;
admin140217
Jason,
adding another selector doesn't seem to do anything to the sub-menu. It stays the same.
not enough coffee, I had a syntax error.
the selector name:
should be:
ul#cssmw > li > ul.level-1 > li > a > li > ul.level-2 > li > a {
admin140217
That doesn't seem to work either!
Is it possible another selector is interfering?
I guess this is one of times where it's better to just do it in a test site than think you can write it on the fly, coffee or not.
here is full tested level 1, 2, and 3 width change css:
width:200px;
left:60px;
ul#cssmw > li > ul.level-1 > li > ul.level-2 > li > a {
width:200px;
ul#cssmw > li > ul.level-1 > li > ul.level-2 > li > ul.level-2 {
left:60px;
ul#cssmw > li > ul.level-1 > li > ul.level-2 > li > ul.level-2 > li > a {
width: 200px;
admin140217
That did it Jason, Thanks a bunch!
you're welcome.
