Data Assist error after created all pages
Thread begun 3/20/2012 7:55 am by santosbr254895 | Last modified 3/20/2012 10:05 am by santosbr254895 | 1480 views | 2 replies |
santosbr254895
Hi Guys,
I have created a test page to use data assist. After I have created all pages by dataassist wizard and tried to see the pages on my browser I just see this message on the pages:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'check
WHERE 0 = 1' at line 1
Even when I try to open a recordset in dreamweaver. a popup windows says:
MySQL Error#: 1064
This is my starting code in check_results.php
<?php require_once('Connections/Con_Check.php'); ?>
if (isset($_GET['S_ID']) && ($_GET['S_ID']) == "") {
$_GET['S_ID'] = "-1";
if (isset($_GET['S_Nome']) && ($_GET['S_Nome']) == "") {
$_GET['S_Nome'] = "-1";
if (isset($_GET['S_Usuario']) && ($_GET['S_Usuario']) == "") {
$_GET['S_Usuario'] = "-1";
Dungol
that code block does not give enough to go on, it is better if you compress the page to a zip archive and attach the zip file to your message so I can see the entire page code.
judging from the error though, it looks like you have a column in your table named "check" which is a reserved word by the MySQL server.
MySQL reserved words should be avoided when naming your tables and columns.
a full list of reserved words can be found here:
reserved-words.html
a common naming convention that I use to avoid this issue is:
-Table Names: use the plural on naming tables:
products
users
options
-Column Names: use the singular table name as a prefix to the column name.
productID
productName
userID
userPassword
userFirstName
userLastName
optionID
optionName
-Both: Use camelCase to avoid illegal spaces, the underscore "_" can be used, but i don't recommend it.
using the singular table name as a prefix will ensure that you will never have 2 tables in your database that have the same name which can cause both errors and confusion. it will also prevent the posibily of using a reserved word. you will still need to be careful when naming the tables though.
santosbr254895
Thanks for your help. It has a long time that I don't use database. I am not so much familiar with MySQL rules.
I removed "-" that I have used in my columns names like ( Prod-Name).
It is OK right now.
