Menu behind Banner
Thread begun 3/20/2012 5:51 am by hbibizadeh396670 | Last modified 7/25/2018 11:35 am by Ray Borduin | 1772 views | 3 replies |
hbibizadeh396670
Menu behind Banner
I am using WOWSlider to create a banner on my website. The issue is the menu nav bar I made with css menu writer has a drop down just above the banner.
The menu appear behind the banner which is a big problem. How do I bring it to the front.
wowslider.com/
it's most likely a z-index issue.
send a link where i can see the problem so i can investigate the cause and find a solution.
BjB
I'm having this problem also. Did you find a resolution?
You just have to adjust the z-index in the css so that the proper one is on top. If you gave me a url to reproduce I could be more specific.
