Create user registration page
Thread begun 3/19/2012 11:32 am by cynthia252501 | Last modified 3/19/2012 1:23 pm by Jason Byrnes | 1040 views | 1 replies |
cynthia252501
I have a page that I have created in Dreamweaver, it is a registration page with unique fiield for the user to input the requested information. My problem is when i select security assist from within the PHP page i don't see where it gives me the option to use my form, only the form that is included with SA and the predetermined fields. I don't even see how i can change the SA fields to match the ones i want to use. Please assist. I am way behind on my deadline. Thank you.
the security assist wizard is used for creating the security assist pages for you.
if you want to use pages wand forms that have already been created, you will need to apply the security assist behaviors to the pages manually.
the registration page is just a page that displays a form, and stores the entered information into a database table using an insert record behavior.
if you want to use your own pages, you will need to add the insert behavior to the registration page, then create the login page and add the log in form and the authenticate user behavior.
it is much easier to use the wizard to create the pages, you can apply your site design to the pages that are created after the wizard is done.
